Install small utilities
Nassefar
Dear community!
I have a rather large file system on my FreeNAS mounted on my Windows boxes. Some operations are rater ineffective to perform from Windows, for example unrar'ing large/many files, since data will be sent back and forth over the network. It will be a lot better with file manipulation locally on FreeNAS.
I am (also after reading the forums) not certain what is the best way to do this... plugin? Jails? I need the utilities to have full access to my files.
If you're running the current version of FreeNAS (9.10.1-U4), it includes mc, which should be able to handle a lot of your file manipulation tasks.
Nassefar
The utilities I want are pigz and par2tbb since I have many cores. Do you know if mc supports something like the ones mentioned?
That, I'm not sure. If it doesn't, creating a jail will give you a basic FreeBSD system, and you can install those utilities the same way you'd install anything else under FreeBSD.
Nassefar
Hm. OK, thanks for the tip. How do I go about accessing all my files from within the jail?
