SOLVED Import Zfs Volum
spyke84
Hi, i'm new of freeNAS and i have a problem with importing a volums: in my home i have a pc with 2 disk 1TB sata and i install freeNAS 9.1.1. When import a Zfs volum i can't create a mirror.
i read the manual and the wiki but the problem persist.
Someone can help me?
thanks a lot
Christian
D
dlavigne
Guest
Are you trying to import an existing mirror or create a new mirror? How are the disks laid out now (filesystem type and RAID type)?
spyke84
I create a new mirror: yesterday night i created a zfs volume, detached the 2 disks ,erased all data and rebooted system. Worked ok!
thanks a lot for response.
Now i would view my foto with my samsung tv in lan. I read that there is a miniDlna plugin to install... i try it :smile:
Bye
toretti
I'm new too and I have a similar issue on FreeNAS-9.2.0-RELEASE-x64.
if I try to auto import volumes , no volume are detected.
If I try to create zfs volume manually I can see drives but, it request me to set a value in empty field , as in attached image.
even if i skip that and try to create volume, then no volumes will be displayed in volume manager
spyke84
Hi torretti,
i create a mirror like you... i click the "plus" button in avaliable disks, and click to drag the indicator in the bar on right... the box to set value disappear...
I hope I was helpful...
bye
