alex87alex
- Jun 28, 2017
Hi everyone, I have recently installed the latest version of truenas, I have an HP Microserver gen10 with 16gb of ram and a 10gbe Intel X540-T2 card fully functional on other systems.
The problem is that truenas only recognizes one port when the card has two.
Can you help me solve?
This is what I see on dmesg:
I think the problem is here:
Thank you for help
---<<BOOT>>---
Copyright (c) 1992-2020 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 12.2-RELEASE-p2 663e6b09467(HEAD) TRUENAS amd64
FreeBSD clang version 10.0.1 (git@github.com:llvm/llvm-project.git llvmorg-10.0.1-0-gef32c611aa2)
VT(efifb): resolution 800x600
CPU: AMD Opteron(tm) X3421 APU (2096.11-MHz K8-class CPU)
Origin="AuthenticAMD" Id=0x660f01 Family=0x15 Model=0x60 Stepping=1
Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
Features2=0x7ed8320b<SSE3,PCLMULQDQ,MON,SSSE3,FMA,CX16,SSE4.1,SSE4.2,MOVBE,POPCNT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND>
AMD Features=0x2e500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM>
AMD Features2=0x2febbfff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,XOP,SKINIT,WDT,LWP,FMA4,TCE,NodeId,TBM,Topology,PCXC,PNXC,<b25>,DBE,PTSC,MWAITX>
Structured Extended Features=0x1a9<FSGSBASE,BMI1,AVX2,SMEP,BMI2>
XSAVE Features=0x1<XSAVEOPT>
SVM: NP,NRIP,VClean,AFlush,DAssist,NAsids=32768
TSC: P-state invariant, performance statistics
real memory = 17179869184 (16384 MB)
avail memory = 15871807488 (15136 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <ALASKA A M I >
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s)
arc4random: no preloaded entropy cache
Firmware Warning (ACPI): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20200430/tbfadt-796)
ioapic0 <Version 2.1> irqs 0-23 on motherboard
ioapic1 <Version 2.1> irqs 24-55 on motherboard
Launching APs: 2 1 3
Timecounter "TSC" frequency 2096107234 Hz quality 1000
random: entropy device external interface
random: registering fast source Intel Secure Key RNG
random: fast provider: "Intel Secure Key RNG"
kbd1 at kbdmux0
mlx5en: Mellanox Ethernet driver 3.5.2 (September 2019)
nexus0
efirtc0: <EFI Realtime Clock> on motherboard
efirtc0: registered as a time-of-day clock, resolution 1.000000s
aesni0: <AES-CBC,AES-CCM,AES-GCM,AES-ICM,AES-XTS> on motherboard
padlock0: No ACE support.
cryptosoft0: <software crypto> on motherboard
acpi0: <ALASKA A M I > on motherboard
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
atrtc0: <AT realtime clock> port 0x70-0x71 on acpi0
atrtc0: registered as a time-of-day clock, resolution 1.000000s
Event timer "RTC" frequency 32768 Hz quality 0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff irq 0,8 on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 450
Event timer "HPET1" frequency 14318180 Hz quality 450
Event timer "HPET2" frequency 14318180 Hz quality 450
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <32-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
apei0: <ACPI Platform Error Interface> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
amdsmn0: <AMD Family 15h System Management Network> on hostb0
amdtemp0: <AMD CPU On-Die Thermal Sensors> on hostb0
pci0: <base peripheral, IOMMU> at device 0.2 (no driver attached)
vgapci0: <VGA-compatible display> port 0xf000-0xf0ff mem 0xe0000000-0xefffffff,0xf0000000-0xf07fffff,0xf0800000-0xf083ffff irq 30 at device 1.0 on pci0
vgapci0: Boot video device
pci0: <multimedia, HDA> at device 1.1 (no driver attached)
pcib1: <ACPI PCI-PCI bridge> at device 2.2 on pci0
pci1: <ACPI PCI bus> on pcib1
ahci0: <Marvell 88SE9230 AHCI SATA controller> port 0xe050-0xe057,0xe040-0xe043,0xe030-0xe037,0xe020-0xe023,0xe000-0xe01f mem 0xfea40000-0xfea407ff irq 32 at device 0.0 on pci1
ahci0: AHCI v1.20 with 8 6Gbps ports, Port Multiplier not supported
ahci0: quirks=0x900<NOBSYRES,ALTSIG>
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich5: <AHCI channel> at channel 5 on ahci0
ahcich6: <AHCI channel> at channel 6 on ahci0
ahcich7: <AHCI channel> at channel 7 on ahci0
pcib2: <ACPI PCI-PCI bridge> at device 2.5 on pci0
pcib2: [GIANT-LOCKED]
pci2: <ACPI PCI bus> on pcib2
bge0: <HP Ethernet 1Gb 2-port 332i Adapter, ASIC rev. 0x5720000> mem 0xf0d50000-0xf0d5ffff,0xf0d40000-0xf0d4ffff,0xf0d30000-0xf0d3ffff irq 27 at device 0.0 on pci2
bge0: APE FW version: NCSI v1.4.1.0
bge0: CHIP ID 0x05720000; ASIC REV 0x5720; CHIP REV 0x57200; PCI-E
miibus0: <MII bus> on bge0
brgphy0: <BCM5720C 1000BASE-T media interface> PHY 1 on miibus0
brgphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
bge0: Using defaults for TSO: 65518/35/2048
bge0: Ethernet address: d0:67:26:d1:8b:56
bge1: <HP Ethernet 1Gb 2-port 332i Adapter, ASIC rev. 0x5720000> mem 0xf0d20000-0xf0d2ffff,0xf0d10000-0xf0d1ffff,0xf0d00000-0xf0d0ffff irq 24 at device 0.1 on pci2
bge1: APE FW version: NCSI v1.4.1.0
bge1: CHIP ID 0x05720000; ASIC REV 0x5720; CHIP REV 0x57200; PCI-E
miibus1: <MII bus> on bge1
brgphy1: <BCM5720C 1000BASE-T media interface> PHY 2 on miibus1
brgphy1: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
bge1: Using defaults for TSO: 65518/35/2048
bge1: Ethernet address: d0:67:26:d1:8b:57
pcib3: <ACPI PCI-PCI bridge> at device 3.1 on pci0
pcib3: failed to allocate initial prefetch window: 0xf0800000-0xf0cfffff
pci3: <ACPI PCI bus> on pcib3
ix0: <Intel(R) PRO/10GbE PCI-Express Network Driver> mem 0xf0a00000-0xf0bfffff,0xf0c04000-0xf0c07fff irq 32 at device 0.0 on pci3
ix0: Using 2048 TX descriptors and 2048 RX descriptors
ix0: Using 4 RX queues 4 TX queues
ix0: Using MSI-X interrupts with 5 vectors
ix0: allocated for 4 queues
ix0: allocated for 4 rx queues
ix0: Ethernet address: a0:36:9f:3f:d1:d0
ix0: PCI Express Bus: Speed 5.0GT/s Width x8
ix1: <Intel(R) PRO/10GbE PCI-Express Network Driver> mem 0xf0c00000-0xf0c03fff irq 35 at device 0.1 on pci3
ix1: 0x200000 bytes of rid 0x10 res 3 failed (0, 0xffffffffffffffff).
ix1: Unable to allocate bus resource: memory
ix1: Allocation of PCI resources failed
ix1: IFDI_ATTACH_PRE failed 6
device_attach: ix1 attach returned 6
pci0: <encrypt/decrypt> at device 8.0 (no driver attached)
xhci0: <XHCI (generic) USB 3.0 controller> mem 0xfeb68000-0xfeb69fff irq 18 at device 16.0 on pci0
xhci0: 32 bytes context size, 64-bit DMA
xhci0: Unable to map MSI-X table
usbus0 on xhci0
usbus0: 5.0Gbps Super Speed USB v3.0
ahci1: <AMD KERNCZ AHCI SATA controller> port 0xf140-0xf147,0xf130-0xf133,0xf120-0xf127,0xf110-0xf113,0xf100-0xf10f mem 0xfeb6d000-0xfeb6d3ff irq 19 at device 17.0 on pci0
ahci1: AHCI v1.30 with 1 6Gbps ports, Port Multiplier supported with FBS
ahcich8: <AHCI channel> at channel 0 on ahci1
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfeb6c000-0xfeb6c0ff irq 18 at device 18.0 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci0
usbus1: 480Mbps High Speed USB v2.0
isab0: <PCI-ISA bridge> at device 20.3 on pci0
isa0: <ISA bus> on isab0
acpi_button0: <Power Button> on acpi0
uart2: <16x50 with 256 byte FIFO> iomem 0xfedc6000-0xfedc7fff irq 10 on acpi0
amdsbwd0: <AMD FCH Rev 41h+ Watchdog Timer> at iomem 0xfed80b00-0xfed80b03,0xfed80b04-0xfed80b07 on isa0
amdsbwd0: watchdog hardware is disabled
device_attach: amdsbwd0 attach returned 6
hwpstate0: <Cool`n'Quiet 2.0> on cpu0
Timecounters tick every 1.000 msec
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
ugen1.1: <AMD EHCI root HUB> at usbus1
ugen0.1: <0x1022 XHCI root HUB> at usbus0
uhub0: <AMD EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
uhub1: <0x1022 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
Trying to mount root from zfs:boot-pool/ROOT/default []...
Root mount waiting for: CAM usbus0 usbus1
ada0 at ahcich8 bus 0 scbus8 target 0 lun 0
ada0: <KINGSTON SA400S37120G SBFK71E0> ACS-4 ATA SATA 3.x device
ada0: Serial Number 50026B778201855B
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 114473MB (234441648 512 byte sectors)
pass0 at ahcich7 bus 0 scbus7 target 0 lun 0
pass0: <Marvell Console 1.01> Removable Processor SCSI device
pass0: Serial Number HKDP221516WL
pass0: 150.000MB/s transfers (SATA 1.x, UDMA4, ATAPI 12bytes, PIO 8192bytes)
uhub1: 8 ports with 8 removable, self powered
uhub0: 2 ports with 2 removable, self powered
ugen0.2: <NOVATEK USB Keyboard> at usbus0
Root mount waiting for: usbus0 usbus1
ukbd0 on uhub1
ukbd0: <NOVATEK USB Keyboard, class 0/0, rev 1.10/1.12, addr 1> on usbus0
kbd2 at ukbd0
uhid0 on uhub1
uhid0: <NOVATEK USB Keyboard, class 0/0, rev 1.10/1.12, addr 1> on usbus0
ugen1.2: <vendor 0x0438 product 0x7900> at usbus1
uhub2 on uhub0
uhub2: <vendor 0x0438 product 0x7900, class 9/0, rev 2.00/0.18, addr 2> on usbus1
uhub2: 4 ports with 4 removable, self powered
random: unblocking device.
intsmb0: <AMD FCH SMBus Controller> at device 20.0 on pci0
smbus0: <System Management Bus> on intsmb0
lo0: link state changed to UP
AMD-Vi: IVRS Info VAsize = 64 PAsize = 48 GVAsize = 2 flags:0
ivhd0: <AMD-Vi/IOMMU ivhd with EFR> on acpi0
ivhd0: Flag:b8<Isoc,IotlbSup,Coherent>
ivhd0: Features(type:0x11) MsiNumPPR = 0 PNBanks= 2 PNCounters= 0
ivhd0: Extended features[31:0]:22294ada<PPRSup,NXSup,GTSup,IASup> HATS = 0x2 GATS = 0x0 GLXSup = 0x1 SmiFSup = 0x1 SmiFRC = 0x2 GAMSup = 0x1 DualPortLogSup = 0x2 DualEventLogSup = 0x2
ivhd0: Extended features[62:32]:77ef<USSup> Max PASID: 0x2f DevTblSegSup = 0x3 MarcSup = 0x1
ivhd0: supported paging level:7, will use only: 4
ivhd0: device range: 0x0 - 0xffff
ivhd0: PCI cap 0x190b640f@0x40 feature:19<IOTLB,EFR,CapExt>
GEOM_ELI: Device ada0p3.eli created.
GEOM_ELI: Encryption: AES-XTS 128
GEOM_ELI: Crypto: hardware
hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> K8/16/48/0x1ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA>
bge1: link state changed to DOWN
ix0: link state changed to UP
bge0: link state changed to DOWN
ix0: link state changed to DOWN
bge0: link state changed to UP
Security policy loaded: MAC/ntpd (mac_ntpd)
kbd1 at kbdmux0
nexus0
usbus0 on xhci0
usbus1 on ehci0
ukbd0 on uhub1
kbd2 at ukbd0
uhid0 on uhub1
uhub2 on uhub0
ix1: <Intel(R) PRO/10GbE PCI-Express Network Driver> mem 0xf0c00000-0xf0c03fff irq 35 at device 0.1 on pci3 ix1: 0x200000 bytes of rid 0x10 res 3 failed (0, 0xffffffffffffffff). ix1: Unable to allocate bus resource: memory ix1: Allocation of PCI resources failed ix1: IFDI_ATTACH_PRE failed 6 device_attach: ix1 attach returned 6 lo0: link state changed to UP ix1: <Intel(R) PRO/10GbE PCI-Express Network Driver> mem 0xf0c00000-0xf0c03fff irq 35 at device 0.1 on pci3 ix1: 0x200000 bytes of rid 0x10 res 3 failed (0, 0xffffffffffffffff). ix1: Unable to allocate bus resource: memory ix1: Allocation of PCI resources failed ix1: IFDI_ATTACH_PRE failed 6
Thank you for help
