I’m new to FreeNAS and curious if my speeds look appropriate for my setup. I’m averaging 112MB/s transferring large files using CIFS from a Windows PC. I know these speeds are good, but do you think I can squeeze out any better transfer rates? Or, should I stop worrying and be happy? Any input/suggestions is greatly appreciated! Thank you in advance.
FreeNAS Server:
FreeNAS-9.3-STABLE-201509220011
Motherboard: SUPERMICRO MBD-X10SL7-F-O
CPU: Intel Xeon E3-1241 v3 3.5GHz
RAM: 32GB Crucial ECC
Hard Drives: 8x 2TB Seagate 6Gb/s 64MB in RAIDz2 (using onboard LSI 2308 flashed to IT)
Add-On cards: Intel PRO/1000PT dual port NIC
autotune turned on
Network Setup:
Switch: Cisco Catalyst 2960G
FreeNAS server is LACP to cisco switch, using all 4 Intel Gbe interfaces (overkill I know)
Client PC also has Intel PRO/1000PT dual NIC LACP to the switch.
Using all certified CAT6 cables.
Client PC:
OS: Windows x64
CPU: i7
RAM: 24GB
HDD: Vertex 4 SSD using to copy to and from FreeNAS server.
Add-On: Intel PRO/1000PT dual NIC
			FreeNAS Server:
autotune turned on
Network Setup:
Client PC:
OS: Windows x64
CPU: i7
RAM: 24GB
