Hi everyone
I have had 6 mirrored vdevs so far and I'm migrating over to two RAIDZ1 vdevs with 6 disks each.
So far everything worked and I'm using send/receive to migrate the date over.
The issue I'm having is that while the new Pool "newstorage" is available in CLI and mounted as /newstorage, the GUI cannot see it. I cannot use it for the system dataset and the disks are displayed as unused. Iwas able to migrate iocage over though.
Does the pool merely need to be mounted under /mnt like the existing ones or am I missing something?
Regards,
Marco
Regards,
Marco
