I am running FreeNAS-8.3.0-RELEASE-p1-x64 (r12825)
I have three hard disk drives in a Raid-Z1 volume. All three disks are new and have no defects.
Tonight, through the FreeNAS web interface, I went to the Volume Status tab and clicked 'Offline' on the first disk in the volume.
My intention was to put the volume into degraded mode, and then re-attach the same disk back to get it to re-silver. However, I am unable to successfully re-attach the disk.
This is the error message:
This is my zpool status output:
I tried several ways to wipe the detached disk (/dev/ada0) and try to re-attach it, but to no avail. I have replaced disks in the past, with a different disk, and that has always worked. But this is the first time I am trying to detach and re-attach the same disk.
As you can see I am at a loss now as to what to do, and my disk array is running in degraded mode.
I appreciate it if someone can help guide me through re-attaching this disk. Thanks!
Dec 22 22:29:57 freenas manage.py: [middleware.exceptions:38] [MiddlewareError: Disk replacement failed: "invalid vdev specification, use '-f' to override the following errors:, /dev/gptid/a44bcc94-6b9b-11e3-b72e-e4115b12c0d0 is part of active pool 'nas_vol01', "]
[root@freenas] ~# zpool status
pool: nas_vol01
state: DEGRADED
status: One or more devices could not be opened. Sufficient replicas exist for
the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
see: http://www.sun.com/msg/ZFS-8000-2Q
scan: scrub repaired 0 in 4h45m with 0 errors on Sat Dec 14 18:49:52 2013
NAME STATE READ WRITE CKSUM
nas_vol01 DEGRADED 0 0 0
raidz1-0 DEGRADED 0 0 0
14951475343142292485 UNAVAIL 0 0 3 was /dev/gptid/29cdff86-6b97-11e3-a9fe-e4115b12c0d0
gptid/25030dad-546a-11e3-9477-e4115b12c0d0 ONLINE 0 0 0
gptid/aa288cf8-6482-11e3-a9fe-e4115b12c0d0 ONLINE 0 0 0
errors: No known data errorsI tried several ways to wipe the detached disk (/dev/ada0) and try to re-attach it, but to no avail. I have replaced disks in the past, with a different disk, and that has always worked. But this is the first time I am trying to detach and re-attach the same disk.
