How to read FreeNAS pool in Ubuntu?
wapster
Hello, TrueNAS (FreeNAS) Guru.
The situation is like this:
my FreeNAS server (11.3) is taking too long to resilvering..., produces errors and generally freezes :(
All this after a sudden power outage.
It was decided to read data from Ubuntu 22.04.3 LTS
To do this I followed the instructions https://openzfs.github.io/openzfs-docs/Getting Started/Ubuntu/index.html#installation
But I don’t see my pool :(
# zpool status
>> no pools available
but the disks themselves are visible in the system:
# lsblk -f
sda
├─sda1
└─sda2      zfs_member 5000  IronWolf 8639906193682941393
sdb
├─sdb1
└─sdb2      zfs_member 5000  IronWolf 8639906193682941393
Tell me how to make disks from FreeNAS readable in Ubuntu (Linux)?
You either forgot to run zpool import or forgot to tell us that you'd run it.
wapster
:rolleyes: Yes, I tried to run
zpool import
but apparently with the wrong flags (options).
As soon as I asked the question, I received an answer :)
This happens often in life...
The correct command for me is this:
sudo zpool import -o readonly=on -f IronWolf
Everything worked!
Thank you very much, Internet and, in particular, this thread
And are you actually seeing an improvement in your original issue? OpenZFS 2.0 brought a bunch of improvements that are missing in FreeNAS 11.x.
