I run two FreeNAS on HP Microservers. After both USB-Bootsticks failed at once (switched to read-only) in one of the FreeNAS I was considering to replace the USB-Sticks with SSD's having seen that a 60 GB SSD is not much more than a 16 GB USB 3.0 stick...
Will I be able to passthrough the SAS disks connected to the Microservers AND upload the existing FreeNAS configuration after FreeNAS is virtalized? Can the virtualized FreeNAS import my existing pool or will I need the copy data to a new pool?
Thank you!
Thank you!
