Letni
 - Jan 22, 2012
Experts,
Running 8.3.0-x64 (pool was built on 8.0.4) and have a RaidZ1 setup with 5 drives. Replaced the smallest drive (1 TB) with a larger one (2 TB) and did not see space expanded (the rest of the drives started out as a mix of 1.5 or 2 TB drives). After reading the forums, I realize that I should have had the autoexpand flag set to true before the drive swap, so after dropping in and resilvering the 2 TB drive, still do NOT see any expanded capacity.. I correctly have the flag set now, but what process should I use to properly recognize up to the 1.5 TB (since it is still a mixture of larger drives)?
Thanks,
LetnI
Thanks,
LetnI
