TheSmoker
- Sep 19, 2012
Hellow everyone!
I have the following configuration:
Supermicro 3U server chassis with redundant PSU
Supermicro Server motherboard with 2 Xeon Quad Core CPUs with 32G ECC Ram
2 M1015 flashed to IT mode
12 x Toshiba Enterprise 2TB@7200 RPM SATA drives
FreeNAS version 9.2.1.6 RC
ZFS RAIDZ2 configured across all 12 drives
FNAS is configured as a files server and linked to an AD/Samba domain running Samba 4.1.6
What i need help with is to set correct ACL permissions for AD users & groups as well as zfs quota on AD user's home directories.
Samba config:
What I am trying to do here is that with every user that logs in AD and accesses the JUKEBOX01 fileserver a home directory will be created and proper permissions and ifs quota will be applied to it.
The script that I've build specifically for this:
The script creates the folders applies correct owner and group based on AD user & group but it does not applies correct user and group ACLs and quota.
When trying to run those commands (setfacl) by hand I get the following errors (test user is tgm):
The thing with setting the quota is a bit different as by hand works but when ran from script it does not:
But when running from script it will do nothing.
Any kind of help would be greatly appreciated.
Also let me know if any additional info in regards to the configuration and the setup is required.
One last comment: until now everything works as advertised. Users, groups, AD, accesses and everything that is AD/fileserver/FreeNAS related. One last thing to make this perfect is to be able to set up permissions and of course quota on homedirs.
Cheers!
Samba config:
[global]
server max protocol = SMB2
encrypt passwords = yes
dns proxy = no
strict locking = no
oplocks = yes
deadtime = 15
max log size = 51200
max open files = 11070
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
getwd cache = yes
guest account = nobody
map to guest = Bad User
obey pam restrictions = Yes
directory name cache size = 0
kernel change notify = no
ea support = yes
store dos attributes = yes
hostname lookups = yes
unix extensions = no
acl allow execute always = true
server role = member server
netbios name = JUKEBOX01
workgroup = LARI
realm = LARI.LOCAL
security = ADS
client use spnego = yes
cache directory = /var/tmp/.cache/.samba
local master = no
domain master = no
preferred master = no
acl check permissions = true
acl map full control = true
dos filemode = yes
idmap config *:backend = tdb
idmap config *:range = 90000000-100000000
winbind cache time = 7200
winbind offline logon = yes
winbind enum users = yes
winbind enum groups = yes
winbind nested groups = yes
winbind use default domain = no
winbind refresh tickets = yes
idmap config LARI: backend = rid
idmap config LARI: range = 20000-20000000
allow trusted domains = no
template shell = /bin/sh
template homedir = /home/%D/%U
pid directory = /var/run/samba
smb passwd file = /var/etc/private/smbpasswd
private dir = /var/etc/private
create mask = 0666
directory mask = 0777
client ntlmv2 auth = yes
dos charset = CP437
unix charset = UTF-8
log level = 1
[homes]
comment = Home Directories
valid users = %D\%U
writable = yes
browseable = no
path = /mnt/tank0/homedirs/%D/%U
directory_mode: parameter = 0700
read only = no
csc policy = documents
root preexec = /mnt/tank0/mksmbhdir.sh %D %U
#!/usr/local/bin/bash
if [ ! -d /mnt/tank0/homedirs/$1/$2 ]; then
/bin/mkdir /mnt/tank0/homedirs/$1/$2
/bin/chmod g+s /mnt/tank0/homedirs/$1/$2
/bin/chown $1\\$2":"LARI\domain users" /mnt/tank0/homedirs/$1/$2
/bin/chmod 770 /mnt/tank0/homedirs/$1/$2
/bin/setfacl -m g:"LARI\domain users":rwx /mnt/tank0/homedirs/$1/$2
/bin/setfacl -m u:\""$1\\$2"\":rwx /mnt/tank0/homedirs/$1/$2
/sbin/zfs set userquota@\""$1\\$2"\"=5G tank0/homedirs
fi
exit 0
[root@jukebox01] /var/log# /bin/setfacl -m g:"LARI\domain users":rwx /mnt/tank0/homedirs/LARI/tgm setfacl: /mnt/tank0/homedirs/LARI/tgm: branding mismatch; existing ACL is NFSv4, entry to be merged is POSIX.1e
[root@jukebox01] /var/log# /bin/setfacl -m u:"LARI\tgm":rwx /mnt/tank0/homedirs/LARI/tgm setfacl: /mnt/tank0/homedirs/LARI/tgm: branding mismatch; existing ACL is NFSv4, entry to be merged is POSIX.1e
[root@jukebox01] ~tgm/secure# zfs list -o userquota@"LARI\tgm" tank0/homedirs
USERQUOTA@LARI\TGM
10G
[root@jukebox01] ~tgm/secure# zfs set userquota@"LARI\tgm"=20G tank0/homedirs
USERQUOTA@LARI\TGM
20G
Cheers!
