How do you mount cifs to rancherOS for container data storage (FN 11.1-U6)?
DD4711
I am trying to get a Plex container up and running but it seems I have problems with mounting cifs shares to rancherOS for container data storage. I am using a fresh installation of FN 11.1-U6.
What I configured:
  • create a user rancher with ID 1100 and a group rancher with ID 1100
  • create dataset video (permission type unix)
  • set permissions for the dataset: user rancher, group rancher (Set permission recursively checked)
  • I checked with ls -l if all folders and files are ranchers files -> they are
  • create a yaml file and merge it with ros config
I tried many many different mount options in the ros configs but I can't get this up and running.
I can't see files in the mounted folder in rancherOS SSH (User rancher, same ID and GID like the FreeNAS User rancher) but I should... sometimes I see files but have no write access...
How do you manage this? How does your mount string looks like? Do I have any problems with user and groups I configured?
Thanks for any help!
All the wisdom I've seen on this says to use NFS for that purpose as SMB/CIFS screws up the permissions.
There are several threads on the forum already explaining how to do that.
DD4711
OK, thanks for answer. I am currently having a look on FreeNAS NFS and the rancher "Rancher NFS" service but also having problems with configuration :( will maybe open a new thread when my research fails...
