So this is what happens when I try to install bignum. So I can understand that it's couldn't find pre built binaries for my version of node and bignumber and I can understand that stuff gets deprecated in newer versions but I don't know enough to progress past here?
root@homebridge:/ # npm install bignum
> bignum@0.12.5 install /node_modules/bignum
> node-pre-gyp install --fallback-to-build
node-pre-gyp ERR! Tried to download(403):
https://rvagg-node.s3-us-west-2.ama....5/bignum-v0.12.5-node-v51-freebsd-x64.tar.gz
node-pre-gyp ERR! Pre-built binaries not found for bignum@0.12.5 and node@7.10.0 (node-v51 ABI) (falling back to source compile with node-gyp)
gmake: Entering directory '/node_modules/bignum/build'
  CXX(target) Release/obj.target/bignum/bignum.o
../bignum.cc:385:24: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
		GetFunction()->NewInstance(len, newArgs);
/root/.node-gyp/7.10.0/include/node/v8.h:3658:31: note: 'NewInstance' has been explicitly marked deprecated here
				Local<Object> NewInstance(int argc, Local<Value> argv[]) const);
../bignum.cc:413:69: warning: 'ToNumber' is deprecated [-Wdeprecated-declarations]
	base = obj->ToObject()->Get(Nan::New("base").ToLocalChecked())->ToNumber()->Value();
/root/.node-gyp/7.10.0/include/node/v8.h:9005:22: note: 'ToNumber' has been explicitly marked deprecated here
Local<Number> Value::ToNumber() const {
../bignum.cc:461:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
  WRAP_RESULT(res, result);
../bignum.cc:70:20: note: expanded from macro 'WRAP_RESULT'
	GetFunction()->NewInstance(1, arg);
../bignum.cc:474:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:488:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:502:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:520:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:538:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:557:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:576:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:585:3: warning: 'ToUint32' is deprecated [-Wdeprecated-declarations]
  REQ_UINT32_ARG(0, x);
../bignum.cc:44:27: note: expanded from macro 'REQ_UINT32_ARG'
  uint32_t VAR = info
->ToUint32()->Value();
/root/.node-gyp/7.10.0/include/node/v8.h:9035:22: note: 'ToUint32' has been explicitly marked deprecated here
Local<Uint32> Value::ToUint32() const {
../bignum.cc:589:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:598:3: warning: 'ToUint32' is deprecated [-Wdeprecated-declarations]
  uint32_t VAR = info->ToUint32()->Value();
../bignum.cc:602:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:614:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:626:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:640:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:659:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:674:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:691:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:707:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:720:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:727:3: warning: 'ToUint32' is deprecated [-Wdeprecated-declarations]
../bignum.cc:734:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:744:3: warning: 'ToUint32' is deprecated [-Wdeprecated-declarations]
  REQ_UINT32_ARG(0, reps);
../bignum.cc:753:3: warning: 'ToUint32' is deprecated [-Wdeprecated-declarations]
  REQ_UINT32_ARG(0, n);
../bignum.cc:994:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:1026:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:1061:3: warning: 'NewInstance' is deprecated [-Wdeprecated-declarations]
../bignum.cc:1085:36: warning: 'ToUint32' is deprecated [-Wdeprecated-declarations]
  unsigned int nCompact = info[0]->ToUint32()->Value();
30 warnings generated.
  SOLINK_MODULE(target) Release/obj.target/bignum.node
  COPY Release/bignum.node
  COPY /node_modules/bignum/binding/bignum.node
  TOUCH Release/obj.target/action_after_build.stamp
gmake: Leaving directory '/node_modules/bignum/build'
npm WARN saveError ENOENT: no such file or directory, open '/package.json'
npm WARN enoent ENOENT: no such file or directory, open '/package.json'
npm WARN !invalid#1 No description
npm WARN !invalid#1 No repository field.
npm WARN !invalid#1 No README data
npm WARN !invalid#1 No license field.
+ bignum@0.12.5
added 113 packages in 23.294s
Everything prior to this goes well from what I can see.
root@homebridge:/ # pkg install -y node npm dbus avahi-libdns gcc
Updating FreeBSD repository catalogue...
pkg: Repository FreeBSD has a wrong packagesite, need to re-create database
[homebridge] Fetching meta.txz: 100%	944 B   0.9kB/s	00:01
[homebridge] Fetching packagesite.txz: 100%	6 MiB   1.0MB/s	00:06
Processing entries: 100%
FreeBSD repository update completed. 26609 packages processed.
All repositories are up to date.
The following 33 package(s) will be affected (of 0 checked):
New packages to be INSTALLED:
		node: 7.10.0
		npm: 5.0.3
		dbus: 1.10.16_1
		avahi-libdns: 0.6.31_2
		gcc: 5.4.0_2
		c-ares: 1.12.0_1
		libuv: 1.12.0
		icu: 58.2_2,1
		python2: 2_3
		gmake: 4.2.1_1
		libX11: 1.6.5,1
		xproto: 7.0.31
		libxcb: 1.12_2
		libXdmcp: 1.1.2
		libXau: 1.0.8_3
		libxml2: 2.9.4
		libpthread-stubs: 0.4
		kbproto: 1.0.7
		libSM: 1.2.2_3,1
		libICE: 1.0.9_1,1
		gnome_subr: 1.0
		avahi-app: 0.6.31_5
		libdaemon: 0.14_1
		gobject-introspection: 1.50.0,1
		glib: 2.50.2_2,1
		libiconv: 1.14_10
		dbus-glib: 0.108
		gcc5: 5.4.0_2
		mpfr: 3.1.5_1
		gmp: 6.1.2
		mpc: 1.0.3
		gcc-ecj: 4.5
		binutils: 2.28,1
Number of packages to be installed: 33
The process will require 739 MiB more space.
127 MiB to be downloaded.
[homebridge] [1/33] Fetching node-7.10.0.txz: 100%	4 MiB 899.7kB/s	00:05
[homebridge] [2/33] Fetching npm-5.0.3.txz: 100%	3 MiB 779.6kB/s	00:04
[homebridge] [3/33] Fetching dbus-1.10.16_1.txz: 100%  331 KiB 338.7kB/s	00:01
[homebridge] [4/33] Fetching avahi-libdns-0.6.31_2.txz: 100%   33 KiB  34.3kB/s	00:01
[homebridge] [5/33] Fetching gcc-5.4.0_2.txz: 100%	804 B   0.8kB/s	00:01
[homebridge] [6/33] Fetching c-ares-1.12.0_1.txz: 100%  120 KiB 122.6kB/s	00:01
[homebridge] [7/33] Fetching libuv-1.12.0.txz: 100%   90 KiB  92.2kB/s	00:01
[homebridge] [8/33] Fetching icu-58.2_2,1.txz: 100%	9 MiB   1.3MB/s	00:07
[homebridge] [9/33] Fetching python2-2_3.txz: 100%	1 KiB   1.1kB/s	00:01
[homebridge] [10/33] Fetching gmake-4.2.1_1.txz: 100%  378 KiB 387.5kB/s	00:01
[homebridge] [11/33] Fetching libX11-1.6.5,1.txz: 100%	2 MiB 556.3kB/s	00:03
[homebridge] [12/33] Fetching xproto-7.0.31.txz: 100%   59 KiB  60.2kB/s	00:01
[homebridge] [13/33] Fetching libxcb-1.12_2.txz: 100%  985 KiB 504.2kB/s	00:02
[homebridge] [14/33] Fetching libXdmcp-1.1.2.txz: 100%   14 KiB  14.1kB/s	00:01
[homebridge] [15/33] Fetching libXau-1.0.8_3.txz: 100%   11 KiB  11.4kB/s	00:01
[homebridge] [16/33] Fetching libxml2-2.9.4.txz: 100%  802 KiB 273.7kB/s	00:03
[homebridge] [17/33] Fetching libpthread-stubs-0.4.txz: 100%	1 KiB   1.0kB/s	00:01
[homebridge] [18/33] Fetching kbproto-1.0.7.txz: 100%  122 KiB 125.1kB/s	00:01
[homebridge] [19/33] Fetching libSM-1.2.2_3,1.txz: 100%   21 KiB  21.9kB/s	00:01
[homebridge] [20/33] Fetching libICE-1.0.9_1,1.txz: 100%   89 KiB  91.4kB/s	00:01
[homebridge] [21/33] Fetching gnome_subr-1.0.txz: 100%	740 B   0.7kB/s	00:01
[homebridge] [22/33] Fetching avahi-app-0.6.31_5.txz: 100%  385 KiB 197.0kB/s	00:02
[homebridge] [23/33] Fetching libdaemon-0.14_1.txz: 100%   22 KiB  22.9kB/s	00:01
[homebridge] [24/33] Fetching gobject-introspection-1.50.0,1.txz: 100%	1 MiB 384.0kB/s	00:03
[homebridge] [25/33] Fetching glib-2.50.2_2,1.txz: 100%	3 MiB 730.0kB/s	00:04
[homebridge] [26/33] Fetching libiconv-1.14_10.txz: 100%  599 KiB 306.8kB/s	00:02
[homebridge] [27/33] Fetching dbus-glib-0.108.txz: 100%  156 KiB 159.4kB/s	00:01
[homebridge] [28/33] Fetching gcc5-5.4.0_2.txz: 100%   81 MiB   4.7MB/s	00:18
[homebridge] [29/33] Fetching mpfr-3.1.5_1.txz: 100%  366 KiB 374.4kB/s	00:01
[homebridge] [30/33] Fetching gmp-6.1.2.txz: 100%  463 KiB 474.1kB/s	00:01
[homebridge] [31/33] Fetching mpc-1.0.3.txz: 100%   72 KiB  73.7kB/s	00:01
[homebridge] [32/33] Fetching gcc-ecj-4.5.txz: 100%	1 MiB 468.1kB/s	00:03
[homebridge] [33/33] Fetching binutils-2.28,1.txz: 100%   19 MiB   2.2MB/s	00:09
Checking integrity... done (0 conflicting)
[homebridge] [1/33] Installing xproto-7.0.31...
[homebridge] [1/33] Extracting xproto-7.0.31: 100%
[homebridge] [2/33] Installing libXdmcp-1.1.2...
[homebridge] [2/33] Extracting libXdmcp-1.1.2: 100%
[homebridge] [3/33] Installing libXau-1.0.8_3...
[homebridge] [3/33] Extracting libXau-1.0.8_3: 100%
[homebridge] [4/33] Installing libxml2-2.9.4...
[homebridge] [4/33] Extracting libxml2-2.9.4: 100%
[homebridge] [5/33] Installing libpthread-stubs-0.4...
[homebridge] [5/33] Extracting libpthread-stubs-0.4: 100%
[homebridge] [6/33] Installing libxcb-1.12_2...
[homebridge] [6/33] Extracting libxcb-1.12_2: 100%
[homebridge] [7/33] Installing kbproto-1.0.7...
[homebridge] [7/33] Extracting kbproto-1.0.7: 100%
[homebridge] [8/33] Installing libICE-1.0.9_1,1...
[homebridge] [8/33] Extracting libICE-1.0.9_1,1: 100%
[homebridge] [9/33] Installing libX11-1.6.5,1...
[homebridge] [9/33] Extracting libX11-1.6.5,1: 100%
[homebridge] [10/33] Installing libSM-1.2.2_3,1...
[homebridge] [10/33] Extracting libSM-1.2.2_3,1: 100%
[homebridge] [11/33] Installing libiconv-1.14_10...
[homebridge] [11/33] Extracting libiconv-1.14_10: 100%
[homebridge] [12/33] Installing gmp-6.1.2...
[homebridge] [12/33] Extracting gmp-6.1.2: 100%
[homebridge] [13/33] Installing dbus-1.10.16_1...
===> Creating groups.
Creating group 'messagebus' with gid '556'.
===> Creating users
Creating user 'messagebus' with uid '556'.
[homebridge] [13/33] Extracting dbus-1.10.16_1: 100%
[homebridge] [14/33] Installing python2-2_3...
[homebridge] [14/33] Extracting python2-2_3: 100%
[homebridge] [15/33] Installing glib-2.50.2_2,1...
[homebridge] [15/33] Extracting glib-2.50.2_2,1: 100%
No schema files found: doing nothing.
[homebridge] [16/33] Installing mpfr-3.1.5_1...
[homebridge] [16/33] Extracting mpfr-3.1.5_1: 100%
[homebridge] [17/33] Installing c-ares-1.12.0_1...
[homebridge] [17/33] Extracting c-ares-1.12.0_1: 100%
[homebridge] [18/33] Installing libuv-1.12.0...
[homebridge] [18/33] Extracting libuv-1.12.0: 100%
[homebridge] [19/33] Installing icu-58.2_2,1...
[homebridge] [19/33] Extracting icu-58.2_2,1: 100%
[homebridge] [20/33] Installing gnome_subr-1.0...
[homebridge] [20/33] Extracting gnome_subr-1.0: 100%
[homebridge] [21/33] Installing libdaemon-0.14_1...
[homebridge] [21/33] Extracting libdaemon-0.14_1: 100%
[homebridge] [22/33] Installing gobject-introspection-1.50.0,1...
[homebridge] [22/33] Extracting gobject-introspection-1.50.0,1: 100%
[homebridge] [23/33] Installing dbus-glib-0.108...
[homebridge] [23/33] Extracting dbus-glib-0.108: 100%
[homebridge] [24/33] Installing mpc-1.0.3...
[homebridge] [24/33] Extracting mpc-1.0.3: 100%
[homebridge] [25/33] Installing gcc-ecj-4.5...
[homebridge] [25/33] Extracting gcc-ecj-4.5: 100%
[homebridge] [26/33] Installing binutils-2.28,1...
[homebridge] [26/33] Extracting binutils-2.28,1: 100%
[homebridge] [27/33] Installing node-7.10.0...
[homebridge] [27/33] Extracting node-7.10.0: 100%
[homebridge] [28/33] Installing gmake-4.2.1_1...
[homebridge] [28/33] Extracting gmake-4.2.1_1: 100%
[homebridge] [29/33] Installing avahi-app-0.6.31_5...
Creating group 'avahi' with gid '558'.
===> Creating users
Creating user 'avahi' with uid '558'.
[homebridge] [29/33] Extracting avahi-app-0.6.31_5: 100%
[homebridge] [30/33] Installing gcc5-5.4.0_2...
[homebridge] [30/33] Extracting gcc5-5.4.0_2: 100%
[homebridge] [31/33] Installing npm-5.0.3...
[homebridge] [31/33] Extracting npm-5.0.3: 100%
[homebridge] [32/33] Installing avahi-libdns-0.6.31_2...
Using existing group 'avahi'.
===> Creating users
Using existing user 'avahi'.
[homebridge] [32/33] Extracting avahi-libdns-0.6.31_2: 100%
[homebridge] [33/33] Installing gcc-5.4.0_2...
[homebridge] Extracting gcc-5.4.0_2: 100%
Message from node-7.10.0:
Note: If you need npm (Node Package Manager), please install www/npm.
Message from gcc5-5.4.0_2:
To ensure binaries built with this toolchain find appropriate versions
of the necessary run-time libraries, you may want to link using
  -Wl,-rpath=/usr/local/lib/gcc5
For ports leveraging USE_GCC, USES=compiler, or USES=fortran this happens
transparently.
root@homebridge:/ # sysrc dbus_enable="YES"
dbus_enable:  -> YES
root@homebridge:/ #
root@homebridge:/ # sysrc avahi_daemon_enable="YES"
avahi_daemon_enable:  -> YES
root@homebridge:/ # ln -s /usr/local/include/avahi-compat-libdns_sd/dns_sd.h /usr/include/dns_sd.h
