SOLVED Home shares stopped working after upgrade to 11.2u2 (from 11.1u6)
nitromaroder
Dear Freenas Community!
I've upgraded my environment to the current 11.2U2 release and noticed, that my samba home shares for the AD users stopped working - but all other samba shares are working fine (i.e. permissions resp. acl's). I've tried also to reset the permissions and acl's but this didn't solve the problem. More over, I've upgraded my 2nd FreeNAS (and zfs pool), and the home-sharing stopped working there as well! #ClassicHomerEffect
Any ideas and hints? The domain joined worked fine, I can list users and group using "wbinfo -u|g", access the normal shares (not inclided in the below config), set acl's using Windows Server (i.e. share type = windows, owner = AD\administrator), and from the smbd log it tries to access the right directory as well: I've created even a new share, assigned "use as home share" - and the home directory for the user also being created, as soon as I try to access "\\FREENAS\userhomedir", but Windows client asks for credentials and the log below shows access denied.
Any help is appreciated!
* /var/log/samba4/log.smbd:
[2019/02/20 17:15:05.093461,  1] ../source3/smbd/service.c:357(create_connection_session_info)
  create_connection_session_info: user 'HOME\administrator' (from session setup) not permitted to access this share (administrator)
[2019/02/20 17:15:05.093498,  1] ../source3/smbd/service.c:529(make_connection_snum)
  create_connection_session_info failed: NT_STATUS_ACCESS_DENIED
* /usr/local/etc/smb4.conf:
[global]
    server min protocol = SMB2_02
    server max protocol = SMB3
    interfaces = 127.0.0.1 192.168.154.11
    bind interfaces only = yes
    encrypt passwords = yes
    dns proxy = no
    strict locking = no
    oplocks = yes
    deadtime = 15
    max log size = 51200
    max open files = 116732
    logging = file
    load printers = no
    printing = bsd
    printcap name = /dev/null
    disable spoolss = yes
    getwd cache = yes
    guest account = nobody
    obey pam restrictions = yes
    ntlm auth = no
    directory name cache size = 0
    kernel change notify = no
    ea support = yes
    store dos attributes = yes
    lm announce = yes
    hostname lookups = yes
    time server = yes
    acl allow execute always = true
    dos filemode = yes
    multicast dns register = yes
    domain logons = no
    idmap config *: backend = tdb
    server role = member server
    workgroup = HOME
    realm = HOME.LOCAL
    security = ADS
    client use spnego = yes
    local master = no
    domain master = no
    preferred master = no
    ads dns update = yes
    winbind cache time = 7200
    winbind offline logon = yes
    winbind enum users = yes
    winbind enum groups = yes
    winbind nested groups = yes
    winbind use default domain = no
    winbind refresh tickets = yes
    idmap config HOME: backend = rid
    idmap config HOME: range = 20000-90000000
    allow trusted domains = yes
    client ldap sasl wrapping = plain
    template shell = /bin/sh
    template homedir = /mnt/data/homes/%D/%U
    netbios name = TROLL
    create mask = 0666
    directory mask = 0777
    client ntlmv2 auth = yes
    dos charset = CP437
    unix charset = UTF-8
    log level = 1
[homes]
    valid users = %D\%U
    path = "/mnt/data/homes/%D/%U"
    comment = Home Directories
    printable = no
    veto files = /.snapshot/.windows/.mac/.zfs/
    writeable = yes
    browseable = yes
    access based share enum = no
    recycle:repository = .recycle/%U
    recycle:keeptree = yes
    recycle:versions = yes
    recycle:touch = yes
    recycle:directory_mode = 0777
    recycle:subdir_mode = 0700
    vfs objects = shadow_copy zfs_space zfsacl streams_xattr recycle
    hide dot files = no
    guest ok = no
    nfs4:mode = special
    nfs4:acedup = merge
    nfs4:chown = true
    zfsacl:acesort = dontcare
Best regards,
Nitro
anodos
Sambassador
