High HDD and CPU use in idle
BET4
Hi everyone. I'm using FreeNAS-8.0.4-RELEASE-p2-x64 (11367).
Some day my wife pulled out flash with freenas so it doesn't work. I reinstalled OS on another flash and run autoimport option for restore access for the data. There's 10TB of stuff.
After that for 22 hours my hdd are 100% in use especially ada4 anda ada5. Is it normal?
    1 users    Load  0.67  0.65  0.30                  Jun 30 12:18
Mem:KB    REAL            VIRTUAL                       VN PAGER   SWAP PAGER
        Tot   Share      Tot    Share    Free           in   out     in   out
Act   97888    8916   511996    10880 7308160  count
All  279864   10104 1074339k    18948          pages
Proc:                                                            Interrupts
  r   p   d   s   w   Csw  Trp  Sys  Int  Sof  Flt        cow   11153 total
             33       10k    8  154 7151 1277   11     11 zfod        atkbd0 1
                                                          ozfod  6028 uart0 irq4
19.0%Sys   4.3%Intr  0.2%User  0.0%Nice 76.6%Idle        %ozfod   292 ata0 irq14
|    |    |    |    |    |    |    |    |    |    |       daefr       ehci0 ehci
==========++                                              prcfr       ohci0 ohci
                                           dtbuf    53155 totfr   830 ahci0 19
Namei     Name-cache   Dir-cache    199978 desvn          react  2001 cpu0: time
   Calls    hits   %    hits   %      3617 numvn          pdwak     1 re0 irq256
     216     216 100                  1006 frevn          pdpgs  2001 cpu1: time
                                                          intrn
Disks   da0  ada0  ada1  ada2  ada3  ada4  ada5    270576 wire
KB/t   0.00 55.45 54.34 54.65 55.03 87.78 88.00     79048 act
tps       0   228   233   231   229   146   145     27288 inact
MB/s   0.00 12.32 12.34 12.31 12.31 12.49 12.48       784 cache
%busy     0    57    56    54    57   100    99   7307376 free
                                                   116336 buf
Is it normal? How long on this volume of information is the process of autoimport?
BET4
Maybe I have to post some other info for clarify situation?
Also it's a problem because of 100% use affect temp of HDD it's between 40 and 43. In normal state it's 35 celsius
BET4
Situation changes from time to time. E.g. now I get this.
    1 users    Load  1.40  0.93  0.69                  Jul  1 23:49
Act  153144   10724   687224    13292 5504100  count
All 1968336   12708 1074521k    27796          pages
Proc:                                                            Interrupts
  r   p   d   s   w   Csw  Trp  Sys  Int  Sof  Flt        cow    7050 total
             38       23k    4   95 3050 3013             zfod        atkbd0 1
                                                          ozfod   350 uart0 irq4
59.4%Sys   8.7%Intr  0.0%User  0.0%Nice 31.9%Idle        %ozfod   828 ata0 irq14
|    |    |    |    |    |    |    |    |    |    |       daefr       ehci0 ehci
==============================++++                        prcfr       ohci0 ohci
                                           dtbuf   162857 totfr  1871 ahci0 19
Namei     Name-cache   Dir-cache    199978 desvn          react  2000 cpu0: time
   Calls    hits   %    hits   %      3999 numvn          pdwak     1 re0 irq256
                                      1071 frevn          pdpgs  2000 cpu1: time
                                                          intrn
Disks   da0  ada0  ada1  ada2  ada3  ada4  ada5   2013508 wire
KB/t   0.00 76.89 76.98 77.57 76.99 92.26 92.30    124944 act
tps       0   502   501   500   499   414   415     42264 inact
MB/s   0.00 37.69 37.67 37.85 37.54 37.28 37.37      1352 cache
%busy     0    20    21    20    21    60    59   5502848 free
                                                   126256 buf
But 5 mins after I get once again 100% busy
I'm sorry, but as I'm somewhat of a noob to BSD myself I don't know what commands will lead to what process is using the disk. I assume if you do a "zpool status" a scrub is not in progress?
BET4
Nope :(
[root@freenas] ~# zpool status
  pool: NAS
 state: ONLINE
 scrub: none requested
        NAME          STATE     READ WRITE CKSUM
        NAS           ONLINE       0     0     0
          raidz1      ONLINE       0     0     0
            gpt/ada0  ONLINE       0     0     0
            gpt/ada1  ONLINE       0     0     0
            gpt/ada2  ONLINE       0     0     0
            gpt/ada3  ONLINE       0     0     0
            gpt/ada4  ONLINE       0     0     0
            gpt/ada5  ONLINE       0     0     0
errors: No known data errors
Unfortunately, I'm out of ideas. I have lots of things I'd want to do like get a breakdown of what is reading and writing, but I don't know how to do that in FreeNAS.
BET4
Meanwhile we I noticed changes some hours ago.
HDD in idle is 0% busy, so it's OK.
But system load and CPU usage still have some activity (but it isn't my activity).
Here's my top. But there's nothing special:
last pid:  4123;  load averages:  0.18,  0.12,  0.09        up 0+05:36:23  21:59:22
40 processes:  1 running, 39 sleeping
CPU:     % user,     % nice,     % system,     % interrupt,     % idle
Mem: 104M Active, 36M Inact, 209M Wired, 1516K Cache, 121M Buf, 7155M Free
Swap: 12G Total, 12G Free
  PID USERNAME    THR PRI NICE   SIZE    RES STATE   C   TIME   WCPU COMMAND
 2438 root          1  48    0 64104K 24460K ttyin   1   9:11  6.05% python
 1933 root          7  44    0 67096K  9676K ucond   0   0:13  0.00% collectd
 1595 root          1  44    0  6776K  1252K select  1   0:05  0.00% powerd
 1836 root          6  44    0   122M 61264K uwait   0   0:05  0.00% python
 1587 root          1  44    0 11784K  2732K select  0   0:01  0.00% ntpd
 2341 www           1  44    0 19332K  4012K kqread  1   0:01  0.00% lighttpd
 2430 root          1  76    0 64104K 24460K ttyin   1   0:01  0.00% python
 1388 root          1  44    0 39216K  6336K select  1   0:00  0.00% nmbd
 2063 root          1  52    0  7836K  1500K nanslp  0   0:00  0.00% cron
 3758 root          1  44    0 33308K  5068K select  0   0:00  0.00% sshd
 1114 root          1  44    0  6908K  1460K select  1   0:00  0.00% syslogd
 1334 root          1  44    0 46792K  9304K select  1   0:00  0.00% smbd
 2256 root          1  44    0  7840K  1528K select  1   0:00  0.00% rpcbind
 3762 root          1  44    0 10176K  2944K pause   0   0:00  0.00% csh
 4090 root          1  44    0 48980K 10044K select  1   0:00  0.00% smbd
 1348 root          1  44    0 46792K  9224K select  0   0:00  0.00% smbd
 2035 root          1  44    0 24980K  4500K select  1   0:00  0.00% sshd
 2260 root          1  76    0  6776K  1552K select  1   0:00  0.00% mountd
 2432 root          1  76    0  6776K  1276K ttyin   1   0:00  0.00% getty
 2431 root          1  76    0  6776K  1276K ttyin   0   0:00  0.00% getty
 2433 root          1  76    0  6776K  1276K ttyin   0   0:00  0.00% getty
 2434 root          1  76    0  6776K  1276K ttyin   0   0:00  0.00% getty
  650 root          1  76    0  5688K  1452K select  1   0:00  0.00% dhclient
 2436 root          1  76    0  6776K  1276K ttyin   0   0:00  0.00% getty
 2437 root          1  76    0  6776K  1276K ttyin   0   0:00  0.00% getty
 2435 root          1  76    0  6776K  1276K ttyin   0   0:00  0.00% getty
 4123 root          1  44    0  9228K  2128K CPU1    1   0:00  0.00% top
  672 _dhcp         1  44    0  5688K  1544K select  1   0:00  0.00% dhclient
  810 root          1  44    0  3204K   716K select  1   0:00  0.00% devd
BET4
Pffff. Without any reason my NAS is going crazy after 2 weeks of wirking OK. System load and hdd load are 100%. Top is showing just 0.10% use of CPU.
