rogerswest
- Aug 3, 2014
...or at least what I'm thinking is a higher end build.
Host:
Chassis: CSE-825MTQ-R700LPB - SMC 2RU
http://www.supermicro.com/products/chassis/2U/825/SC825MTQ-R700LP.cfm
Chassis: 417E16-RJBOD1 - (264 2.5" bay) 3x SMC 4RU 88 2.5" bay JBOD Chassis
http://www.supermicro.com/products/chassis/4U/417/SC417E16-RJBOD1.cfm
For those not keeping count, this system will avail 158.4TB of ZFS space via NFS. More or less.
Some obvious minor issues with this build, that I haven't been able to resolve as of yet:
Kind Regards,
Host:
Main board: X9DRi-LN4F+ - SMC Dual LG2011 24 RDIMM slot http://www.supermicro.com/products/motherboard/Xeon/C600/X9DRi-LN4F_.cfm
http://www.supermicro.com/support/resources/pws/
Operating System Storage: SDSSDRC-032G - 2x SanDisk 32GB SSD using onboard SATAII controller from Main Board and in RAID Level 1 configuration
http://www.sandisk.com/products/ssd/sata/readycache/
SLOG: D2RSTK251S14-0200 - OCZ Deneva 2 R Series 200GB SLC SSD using onboard SATAIII controller from Main Board
http://ocz.com/enterprise/deneva-2-sata-ssd/rs-slc-specifications
JBOD Arrays:Central Processing Unit: E5-2660v2 - 2x Intel 2.2-3.0 GHz 10 Core 20 Thread 25MB cache
http://ark.intel.com/products/75272/Intel-Xeon-Processor-E5-2660-v2-25M-Cache-2_20-GHz
Random Access Memory: (384Gb) KVR13R9D4/16 24x Kingston 16GB Dual Rank ECC DDR3-1333 RDIMM CL9
http://www.kingston.com/dataSheets/KVR13R9D4_16.pdf
Host Bus Adapter: 9300-8e - LSI 12Gb/s 8 port SAS
http://www.lsi.com/products/host-bus-adapters/pages/lsi-sas-9300-8e.aspx
Power Supply: PWS-702A-1R - 2x SMC 700 Watthttp://ark.intel.com/products/75272/Intel-Xeon-Processor-E5-2660-v2-25M-Cache-2_20-GHz
Control Board: CSE-PTJBOD-CB2 - SMC Power Control Board
Backplane: BPN-SAS2-213EL1 - SMC SAS2 Backplane
http://www.supermicro.com/manuals/other/SAS2-213EL.pdf
Backplane: BPN-SAS2-216EL1 - x3 SMC SAS2 Backplane
http://www.supermicro.com/manuals/other/BPN-SAS2-216EL.pdf
Hard Drives: ST600MM0026 - x264 Seagate Savvio SAS 600GB 10,000 RPM 64MB Cache
http://www.seagate.com/internal-har...terprise-performance-10K-hdd/?sku=ST600MM0026
E5-266ov2 supports 4 channel RDIMMs, however the SMC board only has 24 dimm slots in 3 channel config, and at reduced bandwidth (1066 instead of the full support for 1866) so the the ram that I'm putting in will be down rated to 1066 from 1333. It's a bit of shame to loose this bit of bandwidth and more so the extra channel but I haven't found a suitable main board alternative yet. At least not one that I've liked much.- Denva 2 SSD for Slog is only 200GB, its the best I could find out there with power loss safety and SLC. The array will be home primarily to 10-20mb each PDF and TIFF files, as well as hosting ~80 vmdk's for KVM, these vmdk's will be litte more than minimal Centos7 install. Postgres has its own machines so this array will not be used for RDBMS data.
Kind Regards,
