hi,
i have tried my best to read up on the tutorial, as per cyberjocks advise, kindly do not throw me under the bus if what i ask reeks of ignorance.
with that out of the way.
i am planning to build an amd based system. As the only option available to me in india is to either go with the asus p9xd mobos which make the whole setup costly or go with the x79 motherboards. super micro has not landed in a cost effective way in our country.
so here goes.
my objectives
1. really secure data, not encryption as such but i cannot loose the stuff i store. it would contain important documents, photos and priceless videos and memories and some videos which i may at a later stage stream to my htpc.
2. i know raidz1 and 5 are out.
3. also i will go with ecc ram.
now , im not in a position to get 4 wd reds, in one go. so i will have to start with one and work upwards of that.
the build i propose is
fx 6300,
m5a 99x evo -- i heard it has iommu( i dont know if i would need it in a later stage)
Intel EXPI9301CT
and some 16 gigs of ram.
what i'd like to know is
1. should i go with zfs mirror and is zfs mirror secure viz a vis raid z2. which is more secure.
2. i was planning to go for 2* 3tb wd red drives in zfs mirror. what kind of write speeds can i expect? are the write speeds two low?
thanks in advance
so here goes.
my objectives
fx 6300,
Intel EXPI9301CT
thanks in advance
