I have a TrueNAS server with 8 4tb WD NAS drives. Currently, I have my main pool (TANK) in a RadZ2 with 5 4TB drives and a second pool (BACKUP) using the other 3 drives in a RaidZ1. Wondering if this setup makes sense. BACKUP is a bit smaller and is used to replicate TANK. As of now, BACKUP is large enough to replicate TANK in full. TANK is about 10TB with less than 4TB used. BACKUP is 6TB with less than 4TB used. Few setups I can think of are:
1. Leave as is - This will work fine for now but I will need to increase the drive sizes is I fill up BACKUP. This the reason for the question because at some point something will likely need to change.
2. Two Identical Pools - Both TANK and BACKUP are in RAIDZ1 and TANK is replicated to backup. What I like about this is TANK/BACKUP are the same size. I still have redundancy where I don't have an issue unless 2 or more drives in each pool at the same time.
3. RAIDZ2 TANK Pool and Striped BACKUP Pool - TANK stays in RAIDZ2 with 5 drives and I use the other 3 drives striped for BACKUP. This gives about the same size in both. If a drive fails in BACKUP, I have to replace and still have redundancy in TANK.
I realize it somewhat boils down how many belts and suspenders you want to wear. But for an average home user (critical data mostly being digital photos), just looking for some thoughts as to whether this makes sense for an onsite backup (assuming any critical data is already backed up offsite).
Thanks!
Thanks!
