I've been at this for a few days and I'm still scratching my head. I have a nextcloud jail running great (installed as a plugin), but it only works locally (of course, if I open port 80 to my nextcloud IP, I can access remotely no problem, but that isn't secure). Since I'd like to access my nextcloud jail (and a few others) remotely, I decided to setup a NGINX jail so I can reverse proxy. I followed this excellent guide, but I always get 404/not found when I try to configure everything with nextcloud. I can successfully connect to other local servers (e.g. pi-hole). I'm at a loss right now since I feel like I've tried everything. Is anyone successfully pulling off what I'm trying to do? If so, mind giving me a hand with my configurations?
My main configurations are:
Nextcloud Jail usr/local/www/nextcloud/config/config.php
NGINX Jail usr/local/etc/nginx/nginx.conf
NGINX Jail usr/local/etc/nginx/proxy_setup.conf
<?php
$CONFIG = array (
'apps_paths' =>
array (
0 =>
array (
'path' => '/usr/local/www/nextcloud/apps',
'url' => '/apps',
'writable' => true,
1 =>
array (
'path' => '/usr/local/www/nextcloud/apps-pkg',
'url' => '/apps-pkg',
'writable' => true,
'logfile' => '/var/log/nextcloud/nextcloud.log',
'memcache.local' => '\\OC\\Memcache\\APCu',
'instanceid' => 'REMOVED',
'passwordsalt' => 'REMOVED',
'secret' => 'REMOVED',
'trusted_domains' =>
array (
0 => 'NEXTCLOUD.JAIL.IP',
1 => 'MY.DOMAIN',
'datadirectory' => '/usr/local/www/nextcloud/data',
'dbtype' => 'mysql',
'version' => '15.0.0.10',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbport' => '',
'dbtableprefix' => 'oc_',
'dbuser' => 'REMOVED',
'dbpassword' => 'REMOVED',
'installed' => true,
/* 'overwrite.cli.url' => 'https://MY.DOMAIN/', */
'trusted_proxies' =>
array (
0 => 'NGINX.JAIL.IP',
/* 'overwritehost' => 'MY.DOMAIN', */
/* 'overwriteprotocol' => 'https', */
/* 'overwritewebroot' => '/nextcloud', */
);NGINX Jail usr/local/etc/nginx/nginx.conf
#user nobody;
worker_processes 1;
# This default error log path is compiled-in to make sure configuration parsing
# errors are logged somewhere, especially during unattended boot when stderr
# isn't normally logged anywhere. This path will be touched on every nginx
# start regardless of error log location configured here. See
# https://trac.nginx.org/nginx/ticket/147 for more info.
#error_log /var/log/nginx/error.log;
#pid logs/nginx.pid;
events {
worker_connections 1024;
http {
include mime.types;
default_type application/octet-stream;
#log_format main '$remote_addr - $remote_user [$time_local] "$request" '
# '$status $body_bytes_sent "$http_referer" '
# '"$http_user_agent" "$http_x_forwarded_for"';
#access_log logs/access.log main;
sendfile on;
#tcp_nopush on;
#keepalive_timeout 0;
keepalive_timeout 65;
#gzip on;
server {
listen 80;
listen [::]:80;
server_name MY.DOMAIN;
#charset koi8-r;
#access_log logs/host.access.log main;
location / {
root /usr/local/www/nginx;
index index.html index.htm;
#error_page 404 /404.html;
# redirect server error pages to the static page /50x.html
error_page 500 502 503 504 /50x.html;
location = /50x.html {
root /usr/local/www/nginx-dist;
# proxy the PHP scripts to Apache listening on 127.0.0.1:80
#location ~ \.php$ {
# proxy_pass http://127.0.0.1;
# pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
# root html;
# fastcgi_pass 127.0.0.1:9000;
# fastcgi_index index.php;
# fastcgi_param SCRIPT_FILENAME /scripts$fastcgi_script_name;
# include fastcgi_params;
# deny access to .htaccess files, if Apache's document root
# concurs with nginx's one
#location ~ /\.ht {
# deny all;
# another virtual host using mix of IP-, name-, and port-based configuration
#server {
# listen 8000;
# listen somename:8080;
# server_name somename alias another.alias;
# location / {
# root html;
# index index.html index.htm;
# HTTPS server
server {
listen 443 ssl;
listen [::]:443 ssl;
ssl on;
include ssl_common.conf;
include proxy_setup.conf;
# ssl_certificate cert.pem;
# ssl_certificate_key cert.key;
# ssl_session_cache shared:SSL:1m;
# ssl_session_timeout 5m;
# ssl_ciphers HIGH:!aNULL:!MD5;
# ssl_prefer_server_ciphers on;
location / {
}NGINX Jail usr/local/etc/nginx/proxy_setup.conf
location /nextcloud {
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
add_header Strict-Transport-Security "max-age=31536000; includeSubdomains; preload";
add_header Front-End-Https on;
client_max_body_size 16400M;
proxy_pass http://NEXTCLOUD.JAIL.IP;
proxy_pass_header Authorization;
proxy_read_timeout 90;
