vaibhavyagnik
- Aug 26, 2011
I have just built my first FreeNAS. Here are my Hardware specs
1. Processor: AMD Athlonx2 7750 BE @ @.7 Ghz
2. Motherboard: gigabyte GA-MA78GM-S2H
3. 8 GB RAM
4. On board NIC: Realtek 8111C
5. switch: TP-Link TL-SG1005D 5-Port Gigabit Switch. Switch supports Jumbo Frames
6. 4 Western Digital Green WD20EARX 2TB 64MB
7. Freenas is connected to switch via cat5e Cable, 2 M length
8. Client is connected to switch via Cat5e cable, 1 M length
Software specs:
1. Freenas 8.0.4 AMD64 (10351)
2. No tweaks on freenas
3. Client: Windows 7 ultimate, core2duo e8200 @ 3 GHz, 2 GB memory, Atheros 8151 integrated NIC
4. Testing methodology, Intel NAS performance toolkit V 1.7
I have tested various scenarios with different hard drive configuration. I am uploading the spread sheet as an attachment. Kindly refer for viewing performance and giving suggestions.
General copy from windows client to freenas for a 5.8 GB file varies from 45-51 MB/s with 4 disk RAIDZ. Haven't checked the read speeds yet. But i think write speeds can improve.
List of things i have checked:
1. Both the client and freenas are running at gigabit speeds. I know it because the switch indicates it (Green for gigabit and orange for Megabit connection)
2. vfs.zfs.prefetch_disable is set to 0 (checked via ssh command shell)
3. Client is not running with jumbo frames. (checked by going to Manage network adapter>atheros 8151>configure>jumbo frames = disabled) I could have enabled it but wasn't sure what should jumbo rates be. Moreover i am not sure about configuration of NAS NIC. As far as i know, jumbo rates should both be matching on client and host.
4. Ifconfig -a output for NAS box is
My questions are:
1. Is my NAS performance optimum or i require tunning?
2. If tunning is required, what needs to be tuned?
3. for enabling jumbo frames on Freenas what needs to be done?
3. 8 GB RAM
Software specs:
"login as: root
root@192.168.1.3's password:
Last login: Thu Jun 21 19:43:05 2012 from 192.168.1.4
Copyright (c) 1980, 1983, 1986, 1988, 1990, 1991, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD 8.2-RELEASE-p6 (FREENAS.amd64) #0: Tue Feb 28 16:04:44 PST 2012
FreeNAS nanobsd (c) 2009-2010, The FreeNAS Development Team
FreeNAS is under the modified BSD license.
For more information, documentation, help or support, go here:
http://freenas.org
Welcome to FreeNAS
[root@freenas] ~# ifconfig -a
re0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=389b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_UCAST,WOL_MCAST,WOL_MAGIC>
ether 00:1f:d0:d3:6b:1b
inet 192.168.1.3 netmask 0xffffff00 broadcast 192.168.1.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
options=3<RXCSUM,TXCSUM>
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
inet6 ::1 prefixlen 128
nd6 options=3<PERFORMNUD,ACCEPT_RTADV>
[root@freenas] ~#
My questions are:
