Hi all,
Was looking for a bit of help identifying what could be a potential bottleneck or perhaps my mis-understanding, both entirely possible :D
First off the specs:
Dell R510
2 x E5645 @2.4GHz
16 GB DDR3
Intel X520-DA2 SFP+ NIC
Dell Perc H310 cross flashed to IT mode
8 x 2TB WD Red disks in RAIDz2.
Freenas 11.1-U4
Bit of back story, I originally had 4 disks in RAIDz1 (I know) but wanted to expand/change this to the current configuration. So replicated all data off, destroyed original pool and replicated all data back. All is working well.
Before I did this however I wanted to see if there would be any speed improvements from adding additional disks, which I assumed (perhaps incorrectly!) that there would be.
So I installed bonnie++ in a jail and benchmarked several times using the following command:
And it gave the following results:
736MB/s write
542MB/s rewrite
1544MB/s read
1221 IOPS.
Which was all fine and dandy. However after expanding my disks to the 8 x 2TB RAIDz2 configuration, I am still getting identical results as before. This would lead me to think there is a bottleneck. If it had went slightly up or down I would be fine with it but the results are as near as makes no difference identical.
I'm leaning towards the RAM being quite low which I've known for a while and do probably want to get some more anyways, is there anyway to confirm this suspicion? Any other potential bottlenecks?
This isn't really impacting performance at all and I know its a "benchmark" so not really real world scenario, it was more out of curiosity/learning purposes!
Any help much appreciated!
Dell R510
2 x E5645 @2.4GHz
16 GB DDR3
Freenas 11.1-U4
bonnie++ -u root -s 32G -d /tmp -f -b -n 1 -c 4And it gave the following results:
736MB/s write
542MB/s rewrite
1544MB/s read
1221 IOPS.
