My setup:
CPU: Intel i7-2600
MOBO: BioStar TH61 ITX v2.0 (bios flashed to latest 5.02 and I was able to install FreeNAS)
RAM: 16gb (2x 8gb) of Crucial DDR3L-1600 (it's running at 1333, the max the MOBO can support and yes I know ECC RAM is recommended but my CPU doesn't support ECC anyhow)
Storage: 4x 3TB red drives (with RaidZ, no encryption or anything fancy, everything is default)
OS: latest FreeNAS 9.10 stable release
Just wanted to say I'm new to FreeNAS, just built my first box. Read some guidelines, and watched a few youtubes but once I got hang of it, it was pretty easy to set up. My issue now is I got my share setup (SMB), when I transfer a movie files from my Win10 to the share, it's only doing about 7-8mbs!! So I thought it could be my wireless for the Win10 machine, I wired the laptop directly to a LAN port of the same router the FreeNAS is hooked up to, no luck. So I thought my bottleneck could be RAM, so I swapped out the 8gb I had in there initially and put in 16gb (from reading, more RAM always better). Also got new cat5e cable, still no luck. Then I started to research to see if my NIC (Realtek RTL8111E) was compatible, some say it's not, some reported their's working fine and are getting 70-80mb/s. I also looked at my NIC setting in command line and it is showing 1gb full duplex, see below:
I did read somewhere, if I update the driver for the NIC it might resolve slowness issue. There is a new driver out on (10/25/2016 ver. 1.92) listed on realtek's site, but before I follow the step to update it I want to ask some experts on this forum should I do it? even tho FreeNAS is reading my NIC correctly? What else could be bottlenecking my setup that I might be over looking?
Any input is appreciate it, thanks!!
			CPU: Intel i7-2600
re0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE> ether 00:30:67:da: inet 192.168.1.3 netmask 0xffffff00 broadcast 192.168.1.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active
