HyperGrid
- Aug 2, 2013
So, I've got 3 2 TB sata drives that I'd like to put to good use, and I've decided that I will put together a freenas media server using zfs in raidz (raid 5).
The 3 drives I have are:
Seagate Barracuda LP ST32000542AS
These are oldish drives; they run at 5900 rpm's and the sata interface is 3 Gbps.
As I only have 3 drives right now, I'll be buying a fourth drive. I can't find any affordable matching drives (there all around $130, even though there old), so I will be getting newer 2 TB drives that run faster, and probably support 6 Gbps. Will freenas work with different drives in the same array?
And I could really use some budget hardware recommendations.
-jake
-jake
