Geli encrypted drive list not updated correctly when drive is replaced
flami
Hi there,
First things first: I only tried this on 8.3.1 and I really don't want to test it on any newer version
This might be what https://bugs.freenas.org/issues/2178 is talking about.
After I replaced a failing drive in my pool everything worked fine after the resilvering, but for some reason I could not create a recovery key. I kinda forgot about the issue for a few months until I wanted to upgrade this box.
Geli complains that it can not access a certain gptid/7edf... which is the drive I replaced. This id does no longer appear in the storage_disk table of the sqlite database, however it is still present in storage_encryteddisk where the new disk was just added to the end.
I fixed the issue by manually deleting the old record and then uploading the config again, at which point I could create a recovery key again.
So I changed the table from
"id","encrypted_volume_id","encrypted_disk_id","encrypted_provider"
"5","1","5","gptid/7e8e..."
"6","1","6","gptid/7edf..."
"7","1","6","gptid/ed91..."
to
"6","1","6","gptid/ed91..."
Now I don't know if that has been fixed in newer versions and I hope I don't have to test it, but if this is still how Freenas behaves, I think we got a bug. Anyone able to test this?
Greetings,
flami
That is exactly what 2178 is about. I found that bug and I actually created a thread with step-by-step directions for what you did. :P
