crnext
- Aug 22, 2014
Hello to one and all,
I recently installed a FreeNAS server on my home rack, and have since built a new one on a slightly more modern machine, with more storage space, SATA drives, faster processors, more memory, etc.
After much deliberation on how to migrate, (and several failed attampts to use ZFS and rsync) I made the decision to bite the bullet and just use FTP. I have actually started the migration process, and it seems to be running (knock on wood) but this is where my question comes in.
I have opened the web interface to FreeNAS and to FreeNAS2 *FN2 being the newer* and started the FTP through the shell in the web interface. It is plugging right along and much faster than I anticipated. I was wondering if I were to close the shell and/or log out of the web interface would the FTP stop or will it continue to run until the process is finished? I used this command in the source directory: mget *.* /target/directory/on/second/machine *.*
As I mentioned, it is ticking and the directory is filling up with files that I am able to open. I just wonder if I were to close the shell if it would stop running the FTP.
Thanks to all who can answer confidently.
-CR
-CR
