Freenas Pool Offline / Unkown after trying to upgrade drive
Russ12
I was trying to do a simple drive upgrade to one of my pools (For size, not because of an error). I offlined the drive, shut the server down, and then installed the new drive. When I booted back up the server the pool was no longer there. I have my pools configured in a 7-1 ratio so pulling a drive on a pool shouldn't have effected it as there is a spare within the pool and then there is another hot spare on stand-by as well.
Anyway, I put the old drive back in since something wasn't going right and the pool is still unkown / offline. I can see all the drives, I can no longer see the pools even although I put the drive right back in, nothing was erased, simple switched the drive to offline...
Any help greatly appreciated, I can't figure out how to get the volume / pools back online.
D
dlavigne
Guest
Were you able to resolve this? If not, what is the full output of zpool status (within code tags please).
Russ12
I have not been able to resolve it. I will try and figure out how to get that for you now.
Russ12
Russ12
OK that is starting to look like what I used to have. 0415 is the drive I offlined I beleive... and still shows as offline. Do I need to online that drive? if so how?
garm
You didn’t have any errors prior to the disk swap?
