curruscanis
- Feb 15, 2018
Hello, I hoping that the FreeNAS forums can assist me in a sanity check of some of my presumptions.  I have been reading a lot about FreeNAS and everything that it can do.  My specific goal for a new FreeNAS is that of a "SAN" for connecting multiple VMware ESXi hosts.  I have done some virtual testing and understand the basics of how the software works but now I am to the point of throwing money at the solution and want to ensure that I am not just throwing money away.  I have worked extensivly with the DELL MDxxxx series SANS, and a few other NAS solutions like QNAP / Synology and others, I am looking to move away from a vendor like DELL / EMC or similar vendors as they require you to purchase the hardware components from them at far too high a premium.
The FreeNAS solution that I am looking for will handle the following use attributes:
- Enterprise grade hardware ( or as close as possible given lack of dedicated R&D )
- Connect via iSCSI to multiple ESXi hosts - VM counts to be in the 10-20 range varied applications from light Web server use / SQL / AD / File Print Services
- High speed storage for good VM performance
- 2 x 10GB SFP+ networking for redundant iSCSI path
The FreeNAS hardware that I am considering would consist of:
- 8-24 Hot Swap bay chassis as a head unit ( Supermicro? ) - SAS presumed probably with an LSI based HBA controller
- 12-24 Hot Swap bay expansion chassis for future use - possibility of multiple extended chassis would be a plus
- Dual DOM SATA for FreeNAS boot OS
- Hardware to connect head unit to expansion chassis - LSI card with external connector and cable to secondary unit... hardware recommendations?
- RAM - presumably 64Gb or more
- I have not listed disk sizes as it is a variable, I have multiple locations that all require the same solution but not the same data storage needs. I presume that each unit will have multiples of the same size disks in various increments. Presumable 2-4TB SAS disks for an example - extrapolations can be done after the fact for smaller or larger environments.
- I presume a SSD for a ZIL? I don't know the absolute need for this but from what I have read it can help with a storage array for iSCSI.
I have been reviewing various supplies of Supermicro or similar equipment, I will keep my commentary to a single vendor, Thinkmate, as they have a fairly simple configuration page and seem to have a lot of the various Supermicro components that many people recommend on the FreeNAS forums. I am no way associated with Thinkmate, I just found they're configuration system to be easy to use...
So here are some hardware specifications that I configured using the Thinkmate site:
Six-Core Intel® Xeon® Processor E5-2603 v4 1.70GHz 15MB Cache (85W)
Thinkmate® 2U Datacenter Class Passive Heatsink
Intel® C612 Chipset- Dual Intel® Gigabit Ethernet - 10x SATA3 - IPMI 2.0 with LAN
4 x 16GB PC4-19200 2400MHz DDR4 ECC Registered DIMM
Thinkmate® RAX-2308 2U Chassis - 8x Hot-Swap 3.5" SATA/SAS3 - 600W Single Power
2 x 128GB SATA 6.0Gb/s Disk on Module (MLC) (Vertical)
8 x 2.0TB SAS 3.0 12.0Gb/s 7200RPM - 3.5" - Hitachi Ultrastar™ 7K6000 (512e)
LG Slim 8x DVD-RW / 24x CDR Combo (SATA)
LSI SAS 9300-8i SAS 12Gb/s PCIe 3.0 8-Port Host Bus Adapter
Thinkmate® 2U Riser Card - Left Side WIO - 4x PCIe 3.0 x8
Thinkmate® 2U Riser Card - Right Side WIO - 1x PCIe 3.0 x8
Here is the JOBD Expansion chassis:
Thinkmate® STX-2312 2U Chassis - 12x Hot-Swap 3.5" SATA/SAS3 - 12Gb/s SAS Single Expander - 740W Redundant Power
12 x 2.0TB SAS 3.0 12.0Gb/s 7200RPM - 3.5" - Hitachi Ultrastar™ 7K6000 (512e)
LSI SAS 9300-8e SAS 12Gb/s PCIe 3.0 8-Port Host Bus Adapter
2 x 1-Meter External SAS Cable - 12Gb/s to 12Gb/s SAS - SFF-8644 to SFF-8644
I did not include any SSD for the ZIL cache, as I am not sure if I need to ( advise please ).
Thinkmate has this configuration at about $8700.00 not a horrible price, but money spent wisely is cheaper than money spent wrong.
I am not tied to any vendor or hardware at all, but want to keep my considerations to "enterprise" grade hardware that is readily available for a period of time due to any replacement / expansion / or failure of components. Making these systems flexible for scale and price is also a goal, as stated I have many locations that vary in size from 3 esxi hosts with 20+ VM's to location that only have 4 VM's on two hosts.
Reliability is key to my purchasing of any hardware, with the noted exception of not going with a major manufacturers system...
Thank you all for your consideration to this issue, and I hope that I am not being redundant in my request for assistance. I was unable to find much information on "new" hardware and solutions as most people are re purposing existing hardware and questions and comments are tailored to that situation rather than a new build.
