I'm using bacula to regularly backup the whole user data stored on FreeNAS and in addition the /data directory which contains the FreeNAS configuration database. This backup is stored offsite it is mainly done for disaster recovery where either the ZFS Raid dies completely, the machine burns down or similar. Basically assume I have a brand-new box with new drives and this backup. I wanted to discuss what is required to re-build the box while avoiding to re-configure everything from scratch and then just restore the backup.
One approach I thought about would be to:
Has someone already had a similar case and can share experiences?
- Install a fresh FreeNAS on the box, create a ZFS Storage and create all datasets with all names as before
 - Restore the user data from the backup
 - Restore the FreeNAS config from the backup
