SOLVED FreeNAS 9.3 hanging at boot after installation
fabien_r
I try to install FreeNAS 9.3 on the following config: Shuttle SH61R4, Intel i3-2120, 8GB RAM, 2xWD RED 3TB
I downloaded the .iso, checked SHA sum, dumped the image to an USB stick with dd, and installed FreeNAS 9.3 successfully to a 32GB Kingston USB stick.
After rebooting, I'm stuck at the attached picture and I don't know what to do...
Thanks for your help!
D
dlavigne
Guest
Does installing the latest STABLE version fix it? There have been some timeouts added for those systems that need additional time to query the boot device.
