Hello all, I'm going to be taking the plunge into Nas building and decided on a Freenas build.  I'm an experienced PC builder and I recently built a Pfsense box using the Supermicro C2758 board, its worked wonderfully when I don't break it fiddling.   Goals: Build a functional NAS, start small and add to it as time goes on.  Secondary goals:  tinker, break, fix repeat.  File server? Minecraft Server? Learn how to make thin clients? Stream Music and Video?
Board: Supermicro X10SLL-F, I've never had a problem with Supermicro boards.
Processor: i3 4170, mainly for the lower power consumption and cheaper price, I can move up to a Xeon if I find I need it I have a place for the i3 if it gets cut from NAS duty.
Memory: 16gb Kingston KVR16E11/8 to start, another 16gb when I expand the storage.
Boot: 64gb Sata DOM
Drives: 3x 1tb WD Red SATA III drives in Raidz1, I know it's not much but I plan on adding another 3 later and another 3 after that.
Controller: Serveraid M1015 flashed to IT mode for flexibility, I'll populate this card and then move to fill the motherboard sata ports.
NIC: Intel X540-T2 Here is something I need to do some research on, and honestly I will drop if the rewards do not outweigh the expense/time I'm willling to put in. I want my PC, My Pfsense box, and my NAS to be linked with these 10gbe Nics. What I need to look into is if I could do something like this WAN->Pfsense->NAS->PC->Switch->rest of Network. The Pfsense, NAS and PC would be linked with the Cat6 crossover cables, but to be honest networking is still a bit of voodoo for me. Basically, I want the 3 most important components to have 10gbe connections without spending thousands on 3 Nics and a 10gbe switch.
The PSU will be a simple 400w ATX supply and I already have a UPS keeping my PC and Pfsense box protected. Wow, sorry for the huge first post, I'll take any comments or suggestions, Thanks for reading!
Boot: 64gb Sata DOM
