ndboost
- Mar 17, 2013
I currently have the following system:
da0 and da1 are failing with unreadable sectors and i wanted to start putting a plan of action together to upgrade the array to 2TB WD Red's. I will eventually be going for:
So after posting this i realize its probably in the wrong section, and the freenas manual has outlined how to do the steps.. It seems the best method is to replace one drive at a time as money permits, resilver each time.
Will my zpool auto grow once all disks are replaced?
FYI, this is X posted on reddit.. http://www.reddit.com/r/freenas/comments/1qjwno/failing_disks_best_way_to_upgrade_while_replacing/
- 4x 1.5TB Seagate HDDs
- Norco RPC-2008 2U Case
- Super Micro X9SCM-F
- IBM M1015 JBOD
- 32GB DDR3 Memory
- 4x 2TB WD Reds
- 1x 2TB WD Red - offline spare
- how can i swap the HDDs out without losing data, if im using different size and brand disks
- if this isn't possible, will i need to create a new zraid with the new disks and then how do i get the data onto the new disks efficiently
- if i can swap the HDDs, do i do it one at a time slowly as money and time permits and let the raid rebuild each time?
