esxi 6.5 & 11.2-U5 wrong guest OS setting
ShimadaRiku
Fresh install of freenas 11.2-U5 in esxi 6.5, it boots and appears to function okay.
However, esxi complains with this warning message
"The configured guest OS (FreeBSD (64-bit)) for this virtual machine does not match the guest that is currently running (FreeBSD 11.2-STABLE). You should specify the correct guest OS to allow for guest-specific optimizations."
I never got this message when running freenas 9.3 under esxi with the following settings
Guest OS: Other
Guest OS Version: FreeBSD (64-bit)
Guest OS: Other
I have mine (on ESXi 6.7) set to:
Guest OS: Other
Guest OS Version: FreeBSD 11 (64-bit)
It seems to be happy with that.
