downingjosh
- Feb 25, 2013
This is a brand new server with the following specs:
FreeNAS 8.3 p1 x64
Dell T620
1x Xeon E5-2620
32 GB DDR3 1600Mhz
Network - 1x Intel I350 DP (not in use due to driver issues)
Network - 1x Intel dual-port onboard (chipset unknown)
Storage - PERC H310 RAID Controller
4x WD Red 3 TB SATA drives (RAID 10)
4x Samsung 840 Pro 256 GB drives (RAID 10)
Connecting to a vSphere 5.0 server
This is a post for an issue discovered after some troubleshooting in this Networking thread:
http://forums.freenas.org/showthread.php?11424-FreeNAS-resets-network-connections-once-per-minute
We were having issues with the I350 driver resetting every minute, so we tried the onboard NIC instead, but the main symptom is still there. The previous driver resets are gone, but now, we're seeing this entry in 'messages':
Feb 26 19:28:50 freenas istgt[2405]: istgt_lu_disk.c:6737:istgt_lu_disk_execute: ***ERROR*** unsupported SCSI OP=0x4d
Feb 26 19:30:14 freenas last message repeated 2 times
Feb 26 22:05:33 freenas istgt[2405]: Login from iqn.1998-01.com.vmware:localhost-393433a0 (10.1.1.93) on iqn.2011-03.example.org.istgt:datadrive LU2 (10.1.1.91:3260,1), ISID=23d000001, TSIH=2, CID=0, HeaderDigest=off, DataDigest=off
The primary reason we started looking into this issue is that our VMware host (vSphere 5.0) was losing connection to our 'datadrive' iSCSI target. Of the 2 iSCSI targets on the server, only 1 of them is experiencing this problem. 1 is 4 SSDs (Samsung 840 Pro) and the other is 4 rotational drives (Western Digital Reds); the problem only occurs on the Western Digital Red LUN (called 'datadrive' above). The SSDs hold the guest OSes and the WD Reds are given to the file server VM to use as a data drive. This makes me think that the issue may not be strictly with the network card, but perhaps with the drives or their configuration.
I found this thread here:
http://forums.freenas.org/showthread.php?8437-unsupported-SCSI
but we have no monitoring services on the network.
My guess is that it has something to do with the behavior of those Red drives, but I just don't know what. Please let me know what further info I can give you to help. Thanks for everything so far!
FreeNAS 8.3 p1 x64
Dell T620
1x Xeon E5-2620
32 GB DDR3 1600Mhz
