Zwck
- Oct 27, 2016
Hey all,
I installed emby in an iocage and was wondering if this is the correct way or if i missed some important steps, especially when it comes to the FFMPEG compiling. Here is what i have done.
#create emby iocage
#add storage
# Update FreeBSD ports tree modify installation based on emby recomendations
# Remove default FFMpeg package
# Reinstall FFMpeg from ports with lame option enabled
# Install ffmpeg build dependencies
make config
# enable the lame option
# enable the SMB option
# enable the ass subtitles option
# enable the opus subtitles option
# enable the x265 subtitles option
# hit enter a 1000s of times
Add the correct user to emby to start and access the files correctly
To get the current version of emby and not the quarterly once personal fancy
To Update always to the newest version and not the quarterly! Add folder pkg/repos/
FreeBSD: {
url: "pkg+http://pkg.FreeBSD.org/${ABI}/latest"
to update
#create emby iocage
iocage create --name=emby_iocage ip4_addr="igb0|192.168.0.100/24" -r 11.1-RELEASE iocage start emby_iocage
#add storage
iocage fstab -a emby_iocage /mnt/volume01/multimedia /multimedia01 nullfs rw 0 0 iocage fstab -a emby_iocage /mnt/volume02/multimedia /multimedia02 nullfs rw 0 0 iocage fstab -a emby_iocage /mnt/volume01/db/ssl/user-certs /certs nullfs rw 0 0
iocage console emby_iocage pkg install emby-server
portsnap fetch update portsnap extract
pkg delete -f ffmpeg
cd /usr/ports/multimedia/ffmpeg
pkg install `make build-depends-list | tr '\n' ' ' | sed 's/\/usr\/ports\///g' | sed 's/audio\/lame //g'`
make config
make install clean
service emby-server onestop pw useradd -n zwck -u 1000 -d /nonexistent -s /usr/sbin/nologin pw usermod zwck -n emby -u 1000 pw usermod zwck -n emby -g 1000 (where ### is the UID and GID of the user I want it to be) chown -R emby:emby /var/db/emby-server sysrc 'emby_server_user=zwck' service emby-server onestart
chown -R zwck:zwck /var/db/emby-server sysrc 'emby_server_user=zwck'
edit /usr/local/etc/pkg/repos/FreeBSD.confFreeBSD: {
to update
pkg update pkg upgrade
