manifest3r
- Jul 3, 2014
Alright guys...I've had this problem for a while. Just never took the time to actually look into it.
I have the ASUS M5A97 LE R2.0 AM3+ Motherboard, it supports ECC RAM. The ECC RAM I am running is the Kingston KVR13E9/8I 8GB 1333MHz DDR3 PC3-10666 ECC I ran a memtest for 12ish hours, no problem. The CPU I am using is the AMD Athlon II X4 620, which supports ECC RAM as well.
Well...what IS the problem? I haven't been able to put a finger on it, but I am guessing it's some compatibility issue with the RAM. No, I haven't tried non-ECC RAM or another stick of ECC RAM as I do not have the funds to get a spare.
What other troubleshooting steps can I take to make my system more stable or pinpoint what exactly is the issue?
My FreeNAS box returns zero issues when it randomly reboots, it just shuts off, then starts back up. I have tried modifying some BIOS RAM settings, and it went from 1-2 hour reboots to 5-16 hour reboots. I have tried changing memory banks, but it doesn't matter where I put the RAM, it still reboots. I have also tried switching the USB stick FreeNAS is installed on as well as reinstalling FreeNAS from the ground up.
Here's some info about the RAM:
Uptime
EDIT:
10/27: I updated the BIOS from v1903 to v2501, so a HUGE jump. I will update on progress...
10/28: Server rebooted after 16 hours and 30-some minutes. Disabled audio and serial ports on motherboard, as suggested by @Urs.
# dmidecode 2.12
SMBIOS 2.7 present.
Handle 0x002C, DMI type 17, 34 bytes
Memory Device
Array Handle: 0x002A
Error Information Handle: Not Provided
Total Width: Unknown
Data Width: 64 bits
Size: No Module Installed
Form Factor: DIMM
Set: None
Locator: DIMM0
Bank Locator: BANK0
Type: Unknown
Type Detail: Synchronous
Speed: Unknown
Manufacturer: Manufacturer0
Serial Number: SerNum0
Asset Tag: AssetTagNum0
Part Number: Array1_PartNumber0
Rank: Unknown
Configured Clock Speed: Unknown
Handle 0x002E, DMI type 17, 34 bytes
Memory Device
Total Width: 72 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM1
Bank Locator: BANK1
Type: DDR3
Type Detail: Synchronous Unbuffered (Unregistered)
Speed: 1333 MHz
Manufacturer: Kingston
Serial Number: 4424CD7
Asset Tag: AssetTagNum1
Part Number: 9965525-026.A00LF
Rank: 2
Configured Clock Speed: 667 MHz
Handle 0x0030, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM2
Bank Locator: BANK2
Type: Unknown
Speed: Unknown
Manufacturer: Manufacturer2
Serial Number: SerNum2
Asset Tag: AssetTagNum2
Part Number: Array1_PartNumber2
Rank: Unknown
Handle 0x0032, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM3
Bank Locator: BANK3
Type: Unknown
Speed: Unknown
Manufacturer: Manufacturer3
Serial Number: SerNum3
Asset Tag: AssetTagNum3
Part Number: Array1_PartNumber3
Rank: Unknown
Uptime
# uptime 9:49PM up 11:12, 1 user, load averages: 3.05, 1.42, 1.08
EDIT:
