Drives on the way out?
Constantin
Vampire Pig
Hi everyone, I just upgraded my pool to 10GB monsters and got the following messages as I started to populate. I imagine that means I need to return ada2, ada4, and ada5?
New alerts:
* Device: /dev/ada4, 368 Currently unreadable (pending) sectors
* Device: /dev/ada4, 42 Offline uncorrectable sectors
and...
> ahcich2: Timeout on slot 23 port 0
> ahcich2: is 00000008 cs 00000000 ss 00000000 rs 00800000 tfd 40 serr 00000000 cmd 10009717
> (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 60 fe 3f 40 8c 04 00 00 00 00
> (ada2:ahcich2:0:0:0): CAM status: Command timeout
> (ada2:ahcich2:0:0:0): Retrying command
> ahcich5: Timeout on slot 22 port 0
> ahcich5: is 00000008 cs 00000000 ss 00000000 rs 00700000 tfd 40 serr 00000000 cmd 10009617
> (ada5:ahcich5:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 40 fe 3f 40 8c 04 00 00 00 00
> (ada5:ahcich5:0:0:0): CAM status: Command timeout
> (ada5:ahcich5:0:0:0): Retrying command
> ahcich2: Timeout on slot 29 port 0
> ahcich2: is 00000008 cs 00000000 ss 00000000 rs 38000000 tfd 40 serr 00000000 cmd 10009d17
> (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 68 fe 3f 40 8c 04 00 00 00 00
> ahcich5: Timeout on slot 7 port 0
> ahcich5: is 00000008 cs 00000000 ss 00000000 rs 000000c0 tfd 40 serr 00000000 cmd 10008717
> (ada5:ahcich5:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 70 fe 3f 40 8c 04 00 00 00 00
Jailer
Not strong, but bad
Did you test your drives before delpoying them?
Constantin
Vampire Pig
No, and that was a big mistake. Today, I will learn how to burn them in and go from there.
mjt5282
10 GB disks ? ;) Check your cables, too, before going through the RMA process.
Constantin
Vampire Pig
Give me a T! Instead of a G...
I’ll check the cables, they are Supermicro but new to me.
Chris Moore
New alerts:
Some links for you to review.
Building, Burn-In, and Testing your FreeNAS system
https://forums.freenas.org/index.php?resources/building-burn-in-and-testing-your-freenas-system.38/
Github repository for FreeNAS scripts, including disk burnin
https://forums.freenas.org/index.ph...for-freenas-scripts-including-disk-burnin.28/
solnet-array-test (for drive / array speed) non destructive test
https://forums.freenas.org/index.php?resources/solnet-array-test.1/
Useful Commands
https://forums.freenas.org/index.php?threads/useful-commands.30314/#post-195192
Hard Drive Troubleshooting Guide (All Versions of FreeNAS)
https://forums.freenas.org/index.ph...bleshooting-guide-all-versions-of-freenas.17/
