jkingaround
- Sep 12, 2016
Hi all, looking for some help. I recently was getting unreadable sectors on one of my 4tb disks, and ordered a replacement. Since I no longer have any spare bays (using all 24 bays in my chassis) once I got the replacment, I offlined the old disk, shut it down, put the new drive in and hit replace without the usual burn in I did when I had the extra bays. However, something happened while resilvering and it never fully replaced properly. From replies on a reddit thread I was told it was potentially because the WD RED SMR (WD40EFAX) I bought instead of the older CMR version (WD40EFRX) has issues with ZFS/FreeNAS. I have set up a refund and am planning on buying the new (older version) disk as soon as I can get the return dealt with through amazon. However, since my pool is now degraded I would like to put in the old drive that was starting to fail (but the pool wasn't degraded yet) until I can get the new disk popped in there. However, I'm not sure the best way to go about this as I cannot get the drive offline and don't want to risk anything.
What is the best course of action to swap back to the old pre-failing disk? How do I "properly" do a burn in for the replacement without being able to have both disks plugged in at the same time?
Help please.
Server Specs:
Note the scrub cancelled is actually me stopping the resilvering that tried to happen AGAIN after rebooting to see if that helped anything.
Help please.
Server Specs:
CHASSIS: SUPERMICRO 4U 846E16-R1200B
MOBO: X8DTE-F
RAM: 128GB ECC
CPU: Dual Intel XEON L5520
DRIVES: 16 x 4TB WD Red RAID Z2 | 8 x 8TB WD Red RAID Z2
MOBO: X8DTE-F
RAM: 128GB ECC
zpool status -v Chico output:Code:
pool: Chico
state: DEGRADED
scan: scrub canceled on Thu Jun 18 21:20:27 2020
NAME STATE READ WRITE CKSUM
Chico DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
replacing-0 UNAVAIL 0 0 5
7441467098546415565 UNAVAIL 0 0 0 was /dev/gptid/dbd87bda-d718-11e9-b598-000c2920d667
gptid/e981831a-aed7-11ea-aa5d-000c2920d667 FAULTED 0 119 0 too many errors
gptid/de312a5c-d718-11e9-b598-000c2920d667 ONLINE 0 0 0
gptid/e06a57a6-d718-11e9-b598-000c2920d667 ONLINE 0 0 0
gptid/e2b9b37c-d718-11e9-b598-000c2920d667 ONLINE 0 0 0
gptid/e4f9aa44-d718-11e9-b598-000c2920d667 ONLINE 0 0 0
gptid/e71ecdd5-d718-11e9-b598-000c2920d667 ONLINE 0 0 0
gptid/e974b0cb-d718-11e9-b598-000c2920d667 ONLINE 0 0 0
gptid/ebc31519-d718-11e9-b598-000c2920d667 ONLINE 0 0 0
errors: No known data errors
