dmidecode alert
TomasNZ78
Hi there
Any one knows why I get this message on repeat:
alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name
Please help
wblock
Documentation Engineer
Please identify the exact version of FreeNAS being used.
BigDave
FreeNAS Enthusiast
TomasNZ78
I'm running the same version as BigDave
TomasNZ78
I had a look at the bug and my mb is Asus Z87 not ASRock. I didn't have this error on U2 only after I've upgraded to U3
BigDave
FreeNAS Enthusiast
I don't think it's motherboard related as I run a X9-SCM-F and have these log messages as well. I can't wait for the devs to fix this, it drives me nuts.:mad:
Here's a small sample from my log this morning.
May 18 21:18:04 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s system-product-name
May 18 21:18:05 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s baseboard-product-name
May 18 22:18:21 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s system-product-name
May 18 22:18:21 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s baseboard-product-name
May 18 23:18:37 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s system-product-name
May 18 23:18:37 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s baseboard-product-name
May 19 00:00:00 freenas syslog-ng[1645]: Configuration reload request received,  reloading configuration;
May 19 00:18:54 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s system-product-name
May 19 00:18:54 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s baseboard-product-name
May 19 01:19:10 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s system-product-name
May 19 01:19:10 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s baseboard-product-name
May 19 02:19:26 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s system-product-name
May 19 02:19:26 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s baseboard-product-name
May 19 03:19:45 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s system-product-name
May 19 03:19:45 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s baseboard-product-name
May 19 04:20:01 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s system-product-name
May 19 04:20:01 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s baseboard-product-name
May 19 05:20:17 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s system-product-name
May 19 05:20:17 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s baseboard-product-name
May 19 06:20:34 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s system-product-name
May 19 06:20:34 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s baseboard-product-name
May 19 07:20:52 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s system-product-name
May 19 07:20:52 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s baseboard-product-name
May 19 08:21:09 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s system-product-name
May 19 08:21:09 freenas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sb  in/dmidecode -s baseboard-product-name
[root@freenas] ~#
TomasNZ78
yeah it is pretty annoying!
Redcoat
Fixed in 11 at least for my two systems. I had them with the 9.10 versions ...
BigDave
FreeNAS Enthusiast
Really!:eek: You are a brave soul @Redcoat.
There is no way in hell I'd trust my data to a Release Client or a Nightlie version.
I have a test platform on RC2 but that's for testing only.
Redcoat
Ah, actually not that brave. I installed in my main system after having in my backup only to "check it out", then reverted to 9.10.2-U3 again. The install on my backup cleared most of the annoying log messages and I wanted to see the effect on the FreeNAS Mini as the messages were not the same.
TomasNZ78
installed ver 11 and no more of this annoying message
IceBoosteR
I also get this message every hour, and this make my disk spin up every time.
This needs to be fixed asap.
(9.10.2-U3)
nojohnny101
I'm getting these messages as well on FreeNAS-9.10.2-U2 (e1497f2)
Jailer
Not strong, but bad
Target version for the fix is 11 so it's not going away until then. I'm rolling back to 9.10.2-U1 until 11 is ready and tested by the masses.
IceBoosteR
Wow, rollback because of the message?
I will also wait some month or even half a year for stable 11, as a first user of 10 I have learned to wait ;)
I would like to see this to be fixed asap in current 9.10.2-U3 or 9.10.2-U4.
I have opened another bug for this, this messages annoy me.
Jailer
Not strong, but bad
It's slated to be fixed in 11 release which is due out soon. No need to file a new bug report on it since it will likely be closed as a duplicate.
IceBoosteR
No its done.
We will see and mybe this is generating more focus on fixing this.
Where can I find the post when FN11 will be released? Thought this would take some month....
Jailer
Not strong, but bad
It's not fixed in the release product which is 9.10.2. It is fixed in 11 which is in RC status. You can follow the roadmap progress along at bugs.freenas.org of you want to keep up on things but as always watch the forums, web page and blog for release announcements.
