Did I expand my storage correctly?
hendry
Did I expand my "low space" pool, correctly with 2xWD80EFAX 8TB disks using the Add vdevs option? https://youtu.be/V3zapubaNzY?t=315
I.e. not via extending or expanding...
Background: I'm following on from https://www.truenas.com/community/threads/upgrading-storage.79357/#post-550960
https://www.google.com/search?q=truenas+upgrade+pool gives me very poor search results. "https://archive.freenas.org/9.3/" is "Upgrading TrueNAS®"... pardon?
The TrueNAS documentation doesn't appear to mention **Expand pool**. This Reddit comment implies it might be a bad idea?! https://www.reddit.com/r/freenas/comments/ji7qas/upgrade_pool_option/ga57ig8/
Last additional question, is this https://s.natalian.org/2021-01-25/upgrade.png a wise action?
indy
Can you post the output of "zpool status" (with code tags)?
hendry
freenas% zpool status
  pool: freenas-boot
 state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
        still be used, but some features are unavailable.
        the features. See zpool-features(5) for details.
  scan: scrub repaired 0B in 00:01:52 with 0 errors on Sun Jan 24 03:46:52 2021
        NAME          STATE     READ WRITE CKSUM
        freenas-boot  ONLINE       0     0     0
          da0p2       ONLINE       0     0     0
errors: No known data errors
  pool: red
 state: ONLINE
  scan: scrub repaired 0B in 08:21:08 with 0 errors on Sun Dec 27 08:21:08 2020
        red                                             ONLINE       0     0     0
          mirror-0                                      ONLINE       0     0     0
            gptid/d29b9c19-5ed3-11e8-8715-b05ada874af8  ONLINE       0     0     0
            gptid/d3740634-5ed3-11e8-8715-b05ada874af8  ONLINE       0     0     0
          mirror-1                                      ONLINE       0     0     0
            gptid/d891299b-5ec0-11eb-b94b-b05ada874af8  ONLINE       0     0     0
            gptid/d8a3a5c6-5ec0-11eb-b94b-b05ada874af8  ONLINE       0     0     0
freenas%
Alecmascot
Looks fine
Samuel Tai
This is actually a common point of confusion with the documentation. There are 2 ways to expand a pool:
  1. Adding vdevs matching your current pool layout. This sets up a stripe between the current pool members and the new vdevs, which is what you’ve accomplished by adding a 2-disk mirror vdev to your existing 2-disk mirror vdev.
  2. Replacing all pool members with larger disks, assuming you have a pool topology that allows disk replacements without data loss. After the last disk goes in and the resilvering completes, then vdevs in the pool will then reflect the larger disks.
Jailer
Not strong, but bad
