NadoNate
- Aug 7, 2017
I'm running into an error I can't seem to troubleshoot my way out of. I would appreciate any help!
System:
Freenas: FreeNAS-9.10.2-U6 (32GB USB 2)
Storage layout: 1 Pool - 5 4TB (Seagate) RaidZ1-0
Mainboard/CPU: ASUS M5A78L-M, AMD FX(tm)-6350 Six-Core Processor
Memory: 16080MB DDR3-1066
PSU: 500 WATT CoolerMaster 80 plus silver efficiency rating
Issue: Device ada3 detaches randomly, almost once daily. It looks like it is reconnected at some point, and everything reports OK....?
This is the last email alert I received on the 6th:
Troubleshooting steps:
Replace hardware: HDD, SATA cable, Mainboard/CPU
Restore FreeNas defaults
Scrub
Memtest (OK)
Any suggestions would be great! As I have stated, the device in question has been changed out with one of equal size. I don't think I would be seeing the same behavior with two different devices? Could I have a bad PSU?
System:
Aug 5 10:34:53 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 5 10:34:53 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 5 11:35:01 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 5 11:35:01 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 5 12:09:58 lyonas ada3 at ahcich4 bus 0 scbus4 target 0 lun 0 Aug 5 12:09:58 lyonas ada3: <ST4000DM000-1F2168 CC54> s/n S3013JZR detached Aug 5 12:09:58 lyonas GEOM_ELI: Device ada3p1.eli destroyed. Aug 5 12:09:58 lyonas GEOM_ELI: Detached ada3p1.eli on last close. Aug 5 12:09:58 lyonas (ada3:ahcich4:0:0:0): Periph destroyed Aug 5 12:10:04 lyonas ada3 at ahcich4 bus 0 scbus4 target 0 lun 0 Aug 5 12:10:04 lyonas ada3: <ST4000DM000-1F2168 CC54> ACS-2 ATA SATA 3.x device Aug 5 12:10:04 lyonas ada3: Serial Number S3013JZR Aug 5 12:10:04 lyonas ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) Aug 5 12:10:04 lyonas ada3: Command Queueing enabled Aug 5 12:10:04 lyonas ada3: 3815447MB (7814037168 512 byte sectors) Aug 5 12:10:04 lyonas ada3: quirks=0x1<4K> Aug 5 12:10:04 lyonas ada3: Previously was known as ad12 Aug 5 12:10:05 lyonas ZFS: vdev state changed, pool_guid=13987490016491561389 vdev_guid=13611940111043943577 Aug 5 12:35:10 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 5 12:35:10 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 5 13:35:20 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 5 13:35:20 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 5 14:35:32 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 5 14:35:32 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 5 15:35:41 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 5 20:00:27 lyonas manage.py: [common.pipesubr:66] Popen()ing: zfs list -H -o mountpoint,name Aug 5 20:00:29 lyonas notifier: Performing sanity check on Samba configuration: OK Aug 5 20:00:29 lyonas notifier: Reloading nmbd. Aug 5 20:00:29 lyonas notifier: Reloading smbd. Aug 5 20:00:29 lyonas notifier: Reloading winbindd. Aug 5 20:00:29 lyonas smbd: dnssd_clientstub DNSServiceProcessResult called with DNSServiceRef with no ProcessReply function Aug 5 20:00:29 lyonas notifier: Stopping mdnsd. Aug 5 20:00:29 lyonas notifier: Waiting for PIDS: 2835. Aug 5 20:00:29 lyonas notifier: Starting mdnsd. Aug 5 20:00:29 lyonas notifier: Cannot 'reload' netatalk. Set netatalk_enable to YES in /etc/rc.conf or use 'onereload' instead of 'reload'. Aug 5 20:02:04 lyonas manage.py: [common.pipesubr:66] Popen()ing: zfs list -H -o mountpoint,name Aug 5 20:02:13 lyonas manage.py: [common.pipesubr:66] Popen()ing: zfs list -H -o mountpoint,name Aug 5 20:02:13 lyonas manage.py: [common.pipesubr:66] Popen()ing: zfs list -H -o mountpoint,name Aug 5 20:02:15 lyonas notifier: Performing sanity check on Samba configuration: OK Aug 5 20:02:15 lyonas notifier: Reloading nmbd. Aug 5 20:02:15 lyonas notifier: Reloading smbd. Aug 5 20:02:15 lyonas notifier: Reloading winbindd. Aug 5 20:02:15 lyonas notifier: Stopping mdnsd. Aug 5 20:02:15 lyonas notifier: Waiting for PIDS: 46115. Aug 5 20:02:15 lyonas notifier: Starting mdnsd. Aug 5 20:02:15 lyonas notifier: Cannot 'reload' netatalk. Set netatalk_enable to YES in /etc/rc.conf or use 'onereload' instead of 'reload'. Aug 5 20:02:25 lyonas manage.py: [common.pipesubr:66] Popen()ing: zfs list -H -o mountpoint,name Aug 5 20:02:48 lyonas manage.py: [common.pipesubr:66] Popen()ing: zfs list -H -o mountpoint,name Aug 5 20:02:48 lyonas manage.py: [common.pipesubr:66] Popen()ing: zfs list -H -o mountpoint,name Aug 5 20:02:50 lyonas notifier: Performing sanity check on Samba configuration: OK Aug 5 20:02:50 lyonas notifier: Reloading nmbd. Aug 5 20:02:50 lyonas notifier: Reloading smbd. Aug 5 20:02:50 lyonas notifier: Reloading winbindd. Aug 5 20:02:50 lyonas notifier: Stopping mdnsd. Aug 5 20:02:50 lyonas notifier: Waiting for PIDS: 46834. Aug 5 20:02:50 lyonas notifier: Starting mdnsd. Aug 5 20:02:50 lyonas notifier: Cannot 'reload' netatalk. Set netatalk_enable to YES in /etc/rc.conf or use 'onereload' instead of 'reload'. Aug 5 20:11:49 lyonas ada3 at ahcich4 bus 0 scbus4 target 0 lun 0 Aug 5 20:11:49 lyonas ada3: <ST4000DM000-1F2168 CC54> s/n S3013JZR detached Aug 5 20:11:49 lyonas (ada3:ahcich4:0:0:0): Periph destroyed Aug 5 20:11:55 lyonas ada3 at ahcich4 bus 0 scbus4 target 0 lun 0 Aug 5 20:11:55 lyonas ada3: <ST4000DM000-1F2168 CC54> ACS-2 ATA SATA 3.x device Aug 5 20:11:55 lyonas ada3: Serial Number S3013JZR Aug 5 20:11:55 lyonas ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) Aug 5 20:11:55 lyonas ada3: Command Queueing enabled Aug 5 20:11:55 lyonas ada3: 3815447MB (7814037168 512 byte sectors) Aug 5 20:11:55 lyonas ada3: quirks=0x1<4K> Aug 5 20:11:55 lyonas ada3: Previously was known as ad12 Aug 5 20:12:10 lyonas ZFS: vdev state changed, pool_guid=13987490016491561389 vdev_guid=13611940111043943577 Aug 5 20:18:46 lyonas kernel: arp: 192.168.1.11 moved from 02:ff:a0:00:05:0a to 00:1b:21:91:e6:f6 on epair0b Aug 6 00:00:00 lyonas syslog-ng[1480]: Configuration reload request received, reloading configuration; Aug 6 00:37:01 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 6 00:37:01 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 6 01:37:09 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 6 01:37:09 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 6 02:22:45 lyonas ada3 at ahcich4 bus 0 scbus4 target 0 lun 0 Aug 6 02:22:45 lyonas ada3: <ST4000DM000-1F2168 CC54> s/n S3013JZR detached Aug 6 02:22:46 lyonas (ada3:ahcich4:0:0:0): Periph destroyed Aug 6 02:22:51 lyonas ada3 at ahcich4 bus 0 scbus4 target 0 lun 0 Aug 6 02:22:51 lyonas ada3: <ST4000DM000-1F2168 CC54> ACS-2 ATA SATA 3.x device Aug 6 02:22:51 lyonas ada3: Serial Number S3013JZR Aug 6 02:22:51 lyonas ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) Aug 6 02:22:51 lyonas ada3: Command Queueing enabled Aug 6 02:22:51 lyonas ada3: 3815447MB (7814037168 512 byte sectors) Aug 6 02:22:51 lyonas ada3: quirks=0x1<4K> Aug 6 02:22:51 lyonas ada3: Previously was known as ad12 Aug 6 02:22:52 lyonas ZFS: vdev state changed, pool_guid=13987490016491561389 vdev_guid=13611940111043943577 Aug 6 02:27:18 lyonas ada3 at ahcich4 bus 0 scbus4 target 0 lun 0 Aug 6 02:27:18 lyonas ada3: <ST4000DM000-1F2168 CC54> s/n S3013JZR detached Aug 6 02:27:18 lyonas (ada3:ahcich4:0:0:0): Periph destroyed Aug 6 02:27:24 lyonas ada3 at ahcich4 bus 0 scbus4 target 0 lun 0 Aug 6 02:27:24 lyonas ada3: <ST4000DM000-1F2168 CC54> ACS-2 ATA SATA 3.x device Aug 6 02:27:24 lyonas ada3: Serial Number S3013JZR Aug 6 02:27:24 lyonas ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) Aug 6 02:27:24 lyonas ada3: Command Queueing enabled Aug 6 02:27:24 lyonas ada3: 3815447MB (7814037168 512 byte sectors) Aug 6 02:27:24 lyonas ada3: quirks=0x1<4K> Aug 6 02:27:24 lyonas ada3: Previously was known as ad12 Aug 6 02:27:25 lyonas ZFS: vdev state changed, pool_guid=13987490016491561389 vdev_guid=13611940111043943577 Aug 7 00:40:36 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 7 00:40:36 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 7 01:40:43 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 7 01:40:43 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 7 02:40:51 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 7 02:40:51 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 7 03:40:58 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 7 03:40:58 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 7 04:41:05 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 7 04:41:05 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 7 05:41:13 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 7 05:41:13 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 7 06:41:20 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 7 06:41:20 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 7 07:41:30 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 7 07:41:30 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 7 08:41:39 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 7 08:41:39 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 7 09:00:01 lyonas autosnap.py: [tools.autosnap:66] Popen()ing: /sbin/zfs snapshot "HOWITZER@auto-20170807.0900-2w" Aug 7 09:41:49 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 7 09:41:49 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 7 10:00:01 lyonas autosnap.py: [tools.autosnap:66] Popen()ing: /sbin/zfs snapshot "HOWITZER@auto-20170807.1000-2w" Aug 7 10:41:59 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 7 10:41:59 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 7 11:00:01 lyonas autosnap.py: [tools.autosnap:66] Popen()ing: /sbin/zfs snapshot "HOWITZER@auto-20170807.1100-2w" Aug 7 11:37:41 lyonas ada3 at ahcich4 bus 0 scbus4 target 0 lun 0 Aug 7 11:37:41 lyonas ada3: <ST4000DM000-1F2168 CC54> s/n S3013JZR detached Aug 7 11:37:41 lyonas (ada3:ahcich4:0:0:0): Periph destroyed Aug 7 11:37:47 lyonas ada3 at ahcich4 bus 0 scbus4 target 0 lun 0 Aug 7 11:37:47 lyonas ada3: <ST4000DM000-1F2168 CC54> ACS-2 ATA SATA 3.x device Aug 7 11:37:47 lyonas ada3: Serial Number S3013JZR Aug 7 11:37:47 lyonas ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) Aug 7 11:37:47 lyonas ada3: Command Queueing enabled Aug 7 11:37:47 lyonas ada3: 3815447MB (7814037168 512 byte sectors) Aug 7 11:37:47 lyonas ada3: quirks=0x1<4K> Aug 7 11:37:47 lyonas ada3: Previously was known as ad12 Aug 7 11:37:47 lyonas ZFS: vdev state changed, pool_guid=13987490016491561389 vdev_guid=13611940111043943577 Aug 7 11:42:07 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 7 11:42:07 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 7 12:00:01 lyonas autosnap.py: [tools.autosnap:66] Popen()ing: /sbin/zfs snapshot "HOWITZER@auto-20170807.1200-2w" Aug 7 12:42:16 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 7 12:42:16 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 7 13:00:01 lyonas autosnap.py: [tools.autosnap:66] Popen()ing: /sbin/zfs snapshot "HOWITZER@auto-20170807.1300-2w" Aug 7 13:42:25 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 7 13:42:25 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 7 14:00:01 lyonas autosnap.py: [tools.autosnap:66] Popen()ing: /sbin/zfs snapshot "HOWITZER@auto-20170807.1400-2w" Aug 7 14:42:33 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s system-product-name Aug 7 14:42:33 lyonas alert.py: [common.pipesubr:66] Popen()ing: /usr/local/sbin/dmidecode -s baseboard-product-name Aug 7 14:42:59 lyonas kernel: arp: 192.168.1.11 moved from 02:ff:a0:00:05:0a to 00:1b:21:91:e6:f6 on epair0b
lyonas.local changes in mounted filesystems: 4a5 > /mnt/HOWITZER/KIDSTV /mnt/HOWITZER/jails/plexmediaserver_1/media/KIDSTV nullfs rw 0 0 22a24 > HOWITZER/KIDSTV /mnt/HOWITZER/KIDSTV zfs rw,nfsv4acls 0 0 lyonas.local kernel log messages: > ada3 at ahcich4 bus 0 scbus4 target 0 lun 0 > ada3: <ST4000DM000-1F2168 CC54> s/n S3013JZR detached > GEOM_ELI: Device ada3p1.eli destroyed. > GEOM_ELI: Detached ada3p1.eli on last close. > (ada3:ahcich4:0:0:0): Periph destroyed > ada3 at ahcich4 bus 0 scbus4 target 0 lun 0 > ada3: <ST4000DM000-1F2168 CC54> ACS-2 ATA SATA 3.x device > ada3: Serial Number S3013JZR > ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) > ada3: Command Queueing enabled > ada3: 3815447MB (7814037168 512 byte sectors) > ada3: quirks=0x1<4K> > ada3: Previously was known as ad12 > ada3 at ahcich4 bus 0 scbus4 target 0 lun 0 > ada3: <ST4000DM000-1F2168 CC54> s/n S3013JZR detached > (ada3:ahcich4:0:0:0): Periph destroyed > ada3 at ahcich4 bus 0 scbus4 target 0 lun 0 > ada3: <ST4000DM000-1F2168 CC54> ACS-2 ATA SATA 3.x device > ada3: Serial Number S3013JZR > ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) > ada3: Command Queueing enabled > ada3: 3815447MB (7814037168 512 byte sectors) > ada3: quirks=0x1<4K> > ada3: Previously was known as ad12 > arp: 192.168.1.11 moved from 02:ff:a0:00:05:0a to 00:1b:21:91:e6:f6 on epair0b > ada3 at ahcich4 bus 0 scbus4 target 0 lun 0 > ada3: <ST4000DM000-1F2168 CC54> s/n S3013JZR detached > (ada3:ahcich4:0:0:0): Periph destroyed > ada3 at ahcich4 bus 0 scbus4 target 0 lun 0 > ada3: <ST4000DM000-1F2168 CC54> ACS-2 ATA SATA 3.x device > ada3: Serial Number S3013JZR > ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) > ada3: Command Queueing enabled > ada3: 3815447MB (7814037168 512 byte sectors) > ada3: quirks=0x1<4K> > ada3: Previously was known as ad12 > ada3 at ahcich4 bus 0 scbus4 target 0 lun 0 > ada3: <ST4000DM000-1F2168 CC54> s/n S3013JZR detached > (ada3:ahcich4:0:0:0): Periph destroyed > ada3 at ahcich4 bus 0 scbus4 target 0 lun 0 > ada3: <ST4000DM000-1F2168 CC54> ACS-2 ATA SATA 3.x device > ada3: Serial Number S3013JZR > ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) > ada3: Command Queueing enabled > ada3: 3815447MB (7814037168 512 byte sectors) > ada3: quirks=0x1<4K> > ada3: Previously was known as ad12 -- End of security output --
Scrub
Memtest (OK)
