SOLVED Degraded zpool -> Unavailable
g00mbs
Hey There,
My system HW:
  • Asrock C2750D4I (replaced in December 2018 under warranty with the root cause attributed to Intel bug)
  • Crucial 16GB Kit (8GBx2) DDR3/DDR3L-1600MT/s (PC3-12800) DR x8 ECC UDIMM Server Memory CT2KIT102472BD160B/CT2CP102472BD160B
  • SilverStone Technology 450W SFX Form Factor 80 PLUS BRONZE Power Supply with +12V single rail, Active PFC (ST45SF)
  • 6x WD60EFRX (upgraded from WD30EFRX in Nov 2018 to increase storage capacity)
This morning I woke up to
Checking status of zfs pools:
NAME           SIZE  ALLOC   FREE  CKPOINT  EXPANDSZ   FRAG    CAP  DEDUP  HEALTH  ALTROOT
freenas-boot  14.2G  8.36G  5.89G        -         -      -    58%  1.00x  ONLINE  -
pool          32.6T  18.6T  14.0T        -         -    13%    57%  1.00x  DEGRADED  /mnt
  pool: pool
state: DEGRADED
status: One or more devices could not be opened.  Sufficient replicas exist for
        the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
   see: http://illumos.org/msg/ZFS-8000-2Q
  scan: scrub repaired 0 in 0 days 09:48:41 with 0 errors on Sun Mar  3 09:48:44 2019
        pool                                            DEGRADED     0     0     0
          raidz2-0                                      DEGRADED     0     0     0
            10202630468201435458                        UNAVAIL      0     0     0  was /dev/gptid/235b119f-c819-11e7-a1cf-d05099785fe5
            gptid/8757de96-c89c-11e7-af76-d05099785fe5  ONLINE       0     0     0
            gptid/804f5c9f-c90b-11e7-a177-d05099785fe5  ONLINE       0     0     0
            gptid/57173bc9-ca8d-11e7-83d8-d05099785fe5  ONLINE       0     0     0
            gptid/74469597-ca8d-11e7-83d8-d05099785fe5  ONLINE       0     0     0
            gptid/ba57886e-cb4f-11e7-9fab-d05099785fe5  ONLINE       0     0     0
errors: No known data errors
When I got home I rebooted the server and obtained:
~/ $ zpool status
  pool: freenas-boot
state: ONLINE
  scan: scrub repaired 0 in 0 days 00:05:49 with 0 errors on Mon Apr  1 03:50:49 2019
    freenas-boot  ONLINE       0     0     0
      da0p2     ONLINE       0     0     0
  pool: pool
state: ONLINE
status: One or more devices has experienced an unrecoverable error.  An
    attempt was made to correct the error.  Applications are unaffected.
   see: http://illumos.org/msg/ZFS-8000-9P
  scan: resilvered 947M in 0 days 00:00:36 with 0 errors on Thu Apr  4 20:48:13 2019
    pool                                            ONLINE       0     0     0
      raidz2-0                                      ONLINE       0     0     0
        gptid/235b119f-c819-11e7-a1cf-d05099785fe5  ONLINE       0     0    24
At this point, the drive is reconnected and available but with 24 CKSUM errors.
I am unsure what my next troubleshooting step should be to determine if the hard drive is ok. Is anyone able to provide some suggestions on next steps to ensure the drive is usable?
g00mbs
SMART tests attached
  • smart.txt
Chris Moore
I would say, just based on what you have shared, that the drive is done and you may even have other drives that are on their way out. Best to have a look at them all, but plan to replace that one bad actor before it spoils things.
Here is a guide that will help you:
Hard Drive Troubleshooting Guide (All Versions of FreeNAS)
https://forums.freenas.org/index.ph...bleshooting-guide-all-versions-of-freenas.17/
Have you got scheduled SMART short and long testes running?
You could share the output of smartctl -x /dev/da2 substituting your actual drive id instead of da2. The output should look something like this:
# smartctl -x /dev/da2
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Gold
Device Model:     WDC WD6002FRYZ-01WD5B0
Serial Number:    xxxxxxxxx
LU WWN Device Id: 5 000cca 255e8afa6
Firmware Version: 01.01M02
User Capacity:    6,001,175,126,016 bytes [6.00 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Apr  4 23:57:12 2019 CDT
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Disabled
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  113) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 774) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     PO-R--   100   100   016    -    0
  2 Throughput_Performance  P-S---   138   138   054    -    100
  3 Spin_Up_Time            POS---   100   100   024    -    0
  4 Start_Stop_Count        -O--C-   100   100   000    -    1
  5 Reallocated_Sector_Ct   PO--CK   100   100   005    -    0
  7 Seek_Error_Rate         PO-R--   100   100   067    -    0
  8 Seek_Time_Performance   P-S---   140   140   020    -    15
  9 Power_On_Hours          -O--C-   100   100   000    -    1346
10 Spin_Retry_Count        PO--C-   100   100   060    -    0
12 Power_Cycle_Count       -O--CK   100   100   000    -    1
192 Power-Off_Retract_Count -O--CK   098   098   000    -    2953
193 Load_Cycle_Count        -O--C-   098   098   000    -    2953
194 Temperature_Celsius     -O----   162   162   000    -    37 (Min/Max 25/38)
196 Reallocated_Event_Count -O--CK   100   100   000    -    0
197 Current_Pending_Sector  -O---K   100   100   000    -    0
198 Offline_Uncorrectable   ---R--   100   100   000    -    0
199 UDMA_CRC_Error_Count    -O-R--   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      1  Comprehensive SMART error log
0x03       GPL     R/O      1  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x12       GPL     R/O      1  SATA NCQ Non-Data log
0x15       GPL,SL  R/W      1  Rebuild Assist log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    256  Current Device Internal Status Data log
0x25       GPL     R/O    256  Saved Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Extended offline    Completed without error       00%      1342         -
# 2  Short offline       Completed without error       00%      1322         -
# 3  Short offline       Completed without error       00%      1322         -
# 4  Extended offline    Completed without error       00%      1294         -
# 5  Short offline       Completed without error       00%      1274         -
# 6  Short offline       Completed without error       00%      1274         -
# 7  Short offline       Completed without error       00%      1250         -
# 8  Short offline       Completed without error       00%      1250         -
# 9  Short offline       Completed without error       00%      1226         -
#10  Short offline       Completed without error       00%      1226         -
#11  Short offline       Completed without error       00%      1202         -
#12  Short offline       Completed without error       00%      1202         -
#13  Extended offline    Completed without error       00%      1174         -
#14  Short offline       Completed without error       00%      1154         -
#15  Short offline       Completed without error       00%      1154         -
#16  Extended offline    Completed without error       00%      1126         -
#17  Short offline       Completed without error       00%      1106         -
#18  Short offline       Completed without error       00%      1106         -
#19  Short offline       Completed without error       00%      1082         -
SCT Status Version:                  3
SCT Version (vendor specific):       256 (0x0100)
SCT Support Level:                   1
Device State:                        Active (0)
Current Temperature:                    37 Celsius
Power Cycle Min/Max Temperature:     28/38 Celsius
Lifetime    Min/Max Temperature:     25/38 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/60 Celsius
Min/Max Temperature Limit:           -40/70 Celsius
Temperature History Size (Index):    128 (69)
Index    Estimated Time   Temperature Celsius
  70    2019-04-04 21:50    34  ***************
...    ..(  9 skipped).    ..  ***************
  80    2019-04-04 22:00    34  ***************
  81    2019-04-04 22:01    35  ****************
...    ..(  8 skipped).    ..  ****************
  90    2019-04-04 22:10    35  ****************
  91    2019-04-04 22:11    36  *****************
...    ..( 38 skipped).    ..  *****************
   2    2019-04-04 22:50    36  *****************
   3    2019-04-04 22:51    37  ******************
   4    2019-04-04 22:52    37  ******************
   5    2019-04-04 22:53    36  *****************
...    ..(  8 skipped).    ..  *****************
  14    2019-04-04 23:02    36  *****************
  15    2019-04-04 23:03    37  ******************
...    ..(  5 skipped).    ..  ******************
  21    2019-04-04 23:09    37  ******************
  22    2019-04-04 23:10    36  *****************
...    ..(  7 skipped).    ..  *****************
  30    2019-04-04 23:18    36  *****************
  31    2019-04-04 23:19    37  ******************
...    ..(  4 skipped).    ..  ******************
  36    2019-04-04 23:24    37  ******************
  37    2019-04-04 23:25    36  *****************
...    ..(  9 skipped).    ..  *****************
  47    2019-04-04 23:35    36  *****************
  48    2019-04-04 23:36    37  ******************
...    ..(  3 skipped).    ..  ******************
  52    2019-04-04 23:40    37  ******************
  53    2019-04-04 23:41    36  *****************
  61    2019-04-04 23:49    36  *****************
  62    2019-04-04 23:50    37  ******************
  68    2019-04-04 23:56    37  ******************
  69    2019-04-04 23:57    34  ***************
SCT Error Recovery Control:
           Read:     70 (7.0 seconds)
          Write:     70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 2) ==
0x01  0x008  4               1  ---  Lifetime Power-On Resets
0x01  0x018  6      3003990427  ---  Logical Sectors Written
0x01  0x020  6        20130657  ---  Number of Write Commands
0x01  0x028  6     12888726656  ---  Logical Sectors Read
0x01  0x030  6        74419798  ---  Number of Read Commands
0x01  0x038  6      4846305500  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4             889  ---  Spindle Motor Power-on Hours
0x03  0x010  4             889  ---  Head Flying Hours
0x03  0x018  4            2953  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4           27924  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              37  ---  Current Temperature
0x05  0x010  1              35  N--  Average Short Term Temperature
0x05  0x018  1              33  N--  Average Long Term Temperature
0x05  0x020  1              38  ---  Highest Temperature
0x05  0x028  1              25  ---  Lowest Temperature
0x05  0x030  1              37  N--  Highest Average Short Term Temperature
0x05  0x038  1              25  N--  Lowest Average Short Term Temperature
0x05  0x040  1              36  N--  Highest Average Long Term Temperature
0x05  0x048  1              25  N--  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              60  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4               0  ---  Number of Hardware Resets
0x06  0x010  4               0  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2            1  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            1  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000d  2            0  Non-CRC errors within host-to-device FIS
root@Emily-NAS:~ # smartctl
Those results could help us figure out the problem.
Please enclose your listing in code tags like this: [CODE] your list here [/CODE]
Chris Moore
All of these drives are super hot. one of them is 49ºC Need airflow. Make fans go faster or add more fans. Long SMART results with the -X will show more information.
g00mbs
Devices scan:
~/ $ sudo smartctl --scan
/dev/pass0 -d atacam # /dev/pass0, ATA device
/dev/ada0 -d atacam # /dev/ada0, ATA device
/dev/ada1 -d atacam # /dev/ada1, ATA device
/dev/ada2 -d atacam # /dev/ada2, ATA device
/dev/ada3 -d atacam # /dev/ada3, ATA device
/dev/ada4 -d atacam # /dev/ada4, ATA device
/dev/ada5 -d atacam # /dev/ada5, ATA device
/dev/ada0
~/ $ sudo smartctl -x /dev/ada0
Password:
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Model Family:     Western Digital Red
Device Model:     WDC WD60EFRX-68L0BN1
Serial Number:    WD-WX11DC6RDFVT
LU WWN Device Id: 5 0014ee 20e7b185b
Firmware Version: 82.00A82
Rotation Rate:    5700 rpm
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Thu Apr  4 22:17:09 2019 PDT
APM feature is:   Unavailable
ATA Security is:  Disabled, frozen [SEC2]
Offline data collection status:  (0x00)    Offline data collection activity
                    was never started.
                    been run.
data collection:         ( 3584) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    command.
                    power-saving mode.
recommended polling time:      ( 689) minutes.
Conveyance self-test routine
recommended polling time:      (   5) minutes.
SCT capabilities:            (0x303d)    SCT Status supported.
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    0
  3 Spin_Up_Time            POS--K   196   196   021    -    9175
  4 Start_Stop_Count        -O--CK   100   100   000    -    31
  5 Reallocated_Sector_Ct   PO--CK   200   200   140    -    0
  7 Seek_Error_Rate         -OSR-K   200   200   000    -    0
  9 Power_On_Hours          -O--CK   085   085   000    -    11310
 10 Spin_Retry_Count        -O--CK   100   253   000    -    0
 11 Calibration_Retry_Count -O--CK   100   253   000    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    30
192 Power-Off_Retract_Count -O--CK   200   200   000    -    19
193 Load_Cycle_Count        -O--CK   200   200   000    -    123
194 Temperature_Celsius     -O---K   105   093   000    -    47
196 Reallocated_Event_Count -O--CK   200   200   000    -    0
197 Current_Pending_Sector  -O--CK   200   200   000    -    0
198 Offline_Uncorrectable   ----CK   100   253   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    0
200 Multi_Zone_Error_Rate   ---R--   100   253   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      6  Ext. Comprehensive SMART error log
0x0c       GPL     R/O   2048  Pending Defects log
0xa0-0xa7  GPL,SL  VS      16  Device vendor specific log
0xa8-0xb6  GPL,SL  VS       1  Device vendor specific log
0xb7       GPL,SL  VS      54  Device vendor specific log
0xbd       GPL,SL  VS       1  Device vendor specific log
0xc0       GPL,SL  VS       1  Device vendor specific log
0xc1       GPL     VS      93  Device vendor specific log
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 1
    CR     = Command Register
    FEATR  = Features Register
    COUNT  = Count (was: Sector Count) Register
    LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
    LH     = LBA High (was: Cylinder High) Register    ]   LBA
    LM     = LBA Mid (was: Cylinder Low) Register      ] Register
    LL     = LBA Low (was: Sector Number) Register     ]
    DV     = Device (was: Device/Head) Register
    DC     = Device Control Register
    ER     = Error register
    ST     = Status register
Error 1 [0] occurred at disk power-on lifetime: 3170 hours (132 days + 2 hours)
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  40 -- 51 00 00 00 01 4e d2 4f 38 40 00  Error: UNC at LBA = 0x14ed24f38 = 5617372984
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  60 01 00 00 90 00 01 4e d2 50 38 40 08 11d+02:19:02.064  READ FPDMA QUEUED
  60 01 00 00 88 00 01 4e d2 4f 38 40 08 11d+02:19:02.064  READ FPDMA QUEUED
  60 01 00 00 80 00 01 4e d2 4e 38 40 08 11d+02:19:02.052  READ FPDMA QUEUED
  60 01 00 00 78 00 01 4e d2 4d 38 40 08 11d+02:19:02.052  READ FPDMA QUEUED
  60 01 00 00 70 00 01 4e d2 4c 38 40 08 11d+02:19:02.040  READ FPDMA QUEUED
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SCT Version (vendor specific):       258 (0x0102)
Current Temperature:                    47 Celsius
Power Cycle Min/Max Temperature:     42/51 Celsius
Lifetime    Min/Max Temperature:     21/58 Celsius
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Min/Max Temperature Limit:           -41/85 Celsius
Temperature History Size (Index):    478 (355)
 356    2019-04-04 14:20    47  ****************************
 ...    ..( 20 skipped).    ..  ****************************
 377    2019-04-04 14:41    47  ****************************
 378    2019-04-04 14:42    48  *****************************
 ...    ..( 69 skipped).    ..  *****************************
 448    2019-04-04 15:52    48  *****************************
 449    2019-04-04 15:53    47  ****************************
 ...    ..(383 skipped).    ..  ****************************
 355    2019-04-04 22:17    47  ****************************
0x01  0x008  4              30  ---  Lifetime Power-On Resets
0x01  0x010  4           11310  ---  Power-on Hours
0x01  0x018  6     17955889368  ---  Logical Sectors Written
0x01  0x020  6       477035755  ---  Number of Write Commands
0x01  0x028  6    102385653771  ---  Logical Sectors Read
0x01  0x030  6       917552654  ---  Number of Read Commands
0x03  0x008  4           11259  ---  Spindle Motor Power-on Hours
0x03  0x010  4           11259  ---  Head Flying Hours
0x03  0x018  4             143  ---  Head Load Events
0x03  0x028  4              35  ---  Read Recovery Attempts
0x04  0x008  4               1  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               4  ---  Resets Between Cmd Acceptance and Completion
0x05  0x008  1              47  ---  Current Temperature
0x05  0x010  1              47  ---  Average Short Term Temperature
0x05  0x018  1              45  ---  Average Long Term Temperature
0x05  0x020  1              59  ---  Highest Temperature
0x05  0x028  1              27  ---  Lowest Temperature
0x05  0x030  1              57  ---  Highest Average Short Term Temperature
0x05  0x038  1              42  ---  Lowest Average Short Term Temperature
0x05  0x040  1              52  ---  Highest Average Long Term Temperature
0x05  0x048  1              43  ---  Lowest Average Long Term Temperature
0x06  0x008  4             287  ---  Number of Hardware Resets
0x06  0x010  4              76  ---  Number of ASR Events
                                ||__ D supports DSN
Pending Defects log (GP Log 0x0c) supported [please try: '-l defects']
0x0002  2          127  R_ERR response for data FIS
0x0003  2          127  R_ERR response for device-to-host data FIS
0x0005  2            1  R_ERR response for non-data FIS
0x0006  2            1  R_ERR response for device-to-host non-data FIS
0x0008  2            1  Device-to-host non-data FIS retries
0x0009  2          138  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2          141  Device-to-host register FISes sent due to a COMRESET
0x000f  2            0  R_ERR response for host-to-device data FIS, CRC
0x0012  2            0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4      6414510  Vendor specific
/dev/ada1
~/ $ sudo smartctl -x /dev/ada1
Serial Number:    WD-WX31D17DJS93
LU WWN Device Id: 5 0014ee 263d03b3f
Local Time is:    Thu Apr  4 22:18:57 2019 PDT
                    was never started.
                    been run.
data collection:         ( 6824) seconds.
                    command.
                    power-saving mode.
recommended polling time:      ( 722) minutes.
  3 Spin_Up_Time            POS--K   197   197   021    -    9141
  4 Start_Stop_Count        -O--CK   100   100   000    -    28
  9 Power_On_Hours          -O--CK   085   085   000    -    11294
 12 Power_Cycle_Count       -O--CK   100   100   000    -    28
192 Power-Off_Retract_Count -O--CK   200   200   000    -    17
193 Load_Cycle_Count        -O--CK   200   200   000    -    124
194 Temperature_Celsius     -O---K   105   094   000    -    47
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
Device Error Count: 4
    ER     = Error register
Error 4 [3] occurred at disk power-on lifetime: 9506 hours (396 days + 2 hours)
  40 -- 51 00 00 00 00 ef 51 23 a8 40 00  Error: UNC at LBA = 0xef5123a8 = 4015072168
  60 00 40 00 00 00 01 64 b8 a0 b8 40 08     14:28:52.869  READ FPDMA QUEUED
  60 00 40 00 f8 00 01 bf 7e fe 58 40 08     14:28:47.945  READ FPDMA QUEUED
  60 01 00 00 f0 00 00 ef 51 24 a8 40 08     14:28:47.902  READ FPDMA QUEUED
  60 01 00 00 e8 00 00 ef 51 23 a8 40 08     14:28:47.902  READ FPDMA QUEUED
  60 00 40 00 e0 00 00 ef 51 23 68 40 08     14:28:47.892  READ FPDMA QUEUED
Error 3 [2] occurred at disk power-on lifetime: 8194 hours (341 days + 10 hours)
  40 -- 51 00 00 00 00 85 8f 17 08 40 00  Error: UNC at LBA = 0x858f1708 = 2240747272
  60 00 40 00 18 00 01 84 7c 2a 18 40 08 17d+13:27:43.581  READ FPDMA QUEUED
  61 00 40 00 10 00 01 b7 03 ae 80 40 08 17d+13:27:43.369  WRITE FPDMA QUEUED
  60 01 00 00 08 00 00 85 8f 18 08 40 08 17d+13:27:40.231  READ FPDMA QUEUED
  60 01 00 00 00 00 00 85 8f 17 08 40 08 17d+13:27:40.231  READ FPDMA QUEUED
  60 00 40 00 f8 00 00 85 8f 16 c8 40 08 17d+13:27:40.220  READ FPDMA QUEUED
Error 2 [1] occurred at disk power-on lifetime: 5173 hours (215 days + 13 hours)
  40 -- 51 00 00 00 00 87 c2 ff f0 40 00  Error: UNC at LBA = 0x87c2fff0 = 2277703664
  60 00 40 00 40 00 01 97 a4 1b 98 40 08 45d+13:20:02.126  READ FPDMA QUEUED
  60 01 00 00 38 00 00 87 c3 00 f0 40 08 45d+13:20:01.976  READ FPDMA QUEUED
  60 01 00 00 30 00 00 87 c2 ff f0 40 08 45d+13:20:01.976  READ FPDMA QUEUED
  60 01 00 00 28 00 00 87 c2 fe f0 40 08 45d+13:20:01.964  READ FPDMA QUEUED
  60 01 00 00 20 00 00 87 c2 fd f0 40 08 45d+13:20:01.964  READ FPDMA QUEUED
Error 1 [0] occurred at disk power-on lifetime: 19 hours (0 days + 19 hours)
  40 -- 51 00 00 00 00 ef 51 2b 88 40 00  Error: UNC at LBA = 0xef512b88 = 4015074184
  60 01 00 00 58 00 00 ef 51 2c 88 40 08     06:50:02.244  READ FPDMA QUEUED
  60 01 00 00 50 00 00 ef 51 2b 88 40 08     06:50:02.244  READ FPDMA QUEUED
  60 01 00 00 48 00 00 ef 51 2a 88 40 08     06:50:02.232  READ FPDMA QUEUED
  60 01 00 00 40 00 00 ef 51 29 88 40 08     06:50:02.232  READ FPDMA QUEUED
  60 01 00 00 38 00 00 ef 51 28 88 40 08     06:50:02.230  READ FPDMA QUEUED
Vendor specific:
Temperature History Size (Index):    478 (340)
 341    2019-04-04 14:21    47  ****************************
 362    2019-04-04 14:42    47  ****************************
 363    2019-04-04 14:43    48  *****************************
 ...    ..( 78 skipped).    ..  *****************************
 442    2019-04-04 16:02    48  *****************************
 443    2019-04-04 16:03    47  ****************************
 ...    ..(374 skipped).    ..  ****************************
 340    2019-04-04 22:18    47  ****************************
0x01  0x008  4              28  ---  Lifetime Power-On Resets
0x01  0x010  4           11294  ---  Power-on Hours
0x01  0x018  6     17906449792  ---  Logical Sectors Written
0x01  0x020  6       478665844  ---  Number of Write Commands
0x01  0x028  6     96459033262  ---  Logical Sectors Read
0x01  0x030  6       799982940  ---  Number of Read Commands
0x03  0x008  4           11243  ---  Spindle Motor Power-on Hours
0x03  0x010  4           11243  ---  Head Flying Hours
0x03  0x018  4             142  ---  Head Load Events
0x03  0x028  4              95  ---  Read Recovery Attempts
0x04  0x008  4               4  ---  Number of Reported Uncorrectable Errors
0x05  0x020  1              58  ---  Highest Temperature
0x05  0x030  1              55  ---  Highest Average Short Term Temperature
0x05  0x040  1              50  ---  Highest Average Long Term Temperature
0x06  0x008  4             121  ---  Number of Hardware Resets
0x06  0x010  4              52  ---  Number of ASR Events
                                ||__ D supports DSN
0x0009  2           11  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2           14  Device-to-host register FISes sent due to a COMRESET
0x8000  4      6414634  Vendor specific
g00mbs
/dev/ada2
~/ $ sudo smartctl -x /dev/ada2
Serial Number:    WD-WX11DC6RDY36
LU WWN Device Id: 5 0014ee 20e7b1466
Local Time is:    Thu Apr  4 22:21:35 2019 PDT
                    was never started.
                    been run.
data collection:         ( 4604) seconds.
                    command.
                    power-saving mode.
recommended polling time:      ( 700) minutes.
  3 Spin_Up_Time            POS--K   223   197   021    -    7841
  9 Power_On_Hours          -O--CK   085   085   000    -    11281
 12 Power_Cycle_Count       -O--CK   100   100   000    -    27
192 Power-Off_Retract_Count -O--CK   200   200   000    -    18
193 Load_Cycle_Count        -O--CK   200   200   000    -    127
194 Temperature_Celsius     -O---K   108   097   000    -    44
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
Current Temperature:                    44 Celsius
Power Cycle Min/Max Temperature:     38/48 Celsius
Lifetime    Min/Max Temperature:     21/55 Celsius
Vendor specific:
Temperature History Size (Index):    478 (43)
  44    2019-04-04 14:24    44  *************************
  65    2019-04-04 14:45    44  *************************
  66    2019-04-04 14:46    45  **************************
 ...    ..(232 skipped).    ..  **************************
 299    2019-04-04 18:39    45  **************************
 300    2019-04-04 18:40    44  *************************
 ...    ..(220 skipped).    ..  *************************
  43    2019-04-04 22:21    44  *************************
0x01  0x008  4              27  ---  Lifetime Power-On Resets
0x01  0x010  4           11281  ---  Power-on Hours
0x01  0x018  6     17961861280  ---  Logical Sectors Written
0x01  0x020  6       479392872  ---  Number of Write Commands
0x01  0x028  6     91254369209  ---  Logical Sectors Read
0x01  0x030  6       793640788  ---  Number of Read Commands
0x03  0x008  4           11230  ---  Spindle Motor Power-on Hours
0x03  0x010  4           11229  ---  Head Flying Hours
0x03  0x018  4             146  ---  Head Load Events
0x03  0x028  4              18  ---  Read Recovery Attempts
0x05  0x008  1              44  ---  Current Temperature
0x05  0x010  1              44  ---  Average Short Term Temperature
0x05  0x018  1              42  ---  Average Long Term Temperature
0x05  0x020  1              55  ---  Highest Temperature
0x05  0x030  1              52  ---  Highest Average Short Term Temperature
0x05  0x038  1              39  ---  Lowest Average Short Term Temperature
0x05  0x040  1              47  ---  Highest Average Long Term Temperature
0x05  0x048  1              40  ---  Lowest Average Long Term Temperature
0x06  0x008  4             116  ---  Number of Hardware Resets
0x06  0x010  4              51  ---  Number of ASR Events
                                ||__ D supports DSN
0x8000  4      6414807  Vendor specific
/dev/ada3
~/ $ sudo smartctl -x /dev/ada3
Serial Number:    WD-WX11D3744JYY
LU WWN Device Id: 5 0014ee 20eae9f09
Local Time is:    Thu Apr  4 22:22:09 2019 PDT
                    was never started.
                    been run.
data collection:         ( 6164) seconds.
                    command.
                    power-saving mode.
recommended polling time:      ( 715) minutes.
  3 Spin_Up_Time            POS--K   197   197   021    -    9150
  4 Start_Stop_Count        -O--CK   100   100   000    -    25
  9 Power_On_Hours          -O--CK   085   085   000    -    11235
 12 Power_Cycle_Count       -O--CK   100   100   000    -    25
194 Temperature_Celsius     -O---K   112   104   000    -    40
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
Device Error Count: 2
    ER     = Error register
Error 2 [1] occurred at disk power-on lifetime: 2094 hours (87 days + 6 hours)
  40 -- 51 00 00 00 00 98 30 97 a8 40 00  Error: UNC at LBA = 0x983097a8 = 2553321384
  60 00 40 00 80 00 01 6b 5d b5 c0 40 08 19d+02:43:46.666  READ FPDMA QUEUED
  60 00 40 00 78 00 01 6f de 45 10 40 08 19d+02:43:46.355  READ FPDMA QUEUED
  60 00 40 00 70 00 01 6f de 44 d0 40 08 19d+02:43:46.355  READ FPDMA QUEUED
  60 00 40 00 68 00 01 6f de 44 90 40 08 19d+02:43:46.355  READ FPDMA QUEUED
  60 01 00 00 60 00 00 98 30 98 a8 40 08 19d+02:43:43.649  READ FPDMA QUEUED
Error 1 [0] occurred at disk power-on lifetime: 1086 hours (45 days + 6 hours)
  40 -- 51 00 00 00 00 c0 22 bd 98 40 00  Error: UNC at LBA = 0xc022bd98 = 3223502232
  60 00 40 00 80 00 00 d5 96 38 08 40 08 26d+19:36:50.831  READ FPDMA QUEUED
  60 01 00 00 78 00 00 c0 22 be 98 40 08 26d+19:36:46.071  READ FPDMA QUEUED
  60 01 00 00 70 00 00 c0 22 bd 98 40 08 26d+19:36:46.071  READ FPDMA QUEUED
  60 01 00 00 68 00 00 c0 22 bc 98 40 08 26d+19:36:46.059  READ FPDMA QUEUED
  60 01 00 00 60 00 00 c0 22 bb 98 40 08 26d+19:36:46.059  READ FPDMA QUEUED
Current Temperature:                    40 Celsius
Power Cycle Min/Max Temperature:     35/42 Celsius
Lifetime    Min/Max Temperature:     21/48 Celsius
Vendor specific:
Temperature History Size (Index):    478 (167)
 168    2019-04-04 14:25    39  ********************
 ...    ..( 14 skipped).    ..  ********************
 183    2019-04-04 14:40    39  ********************
 184    2019-04-04 14:41    40  *********************
 ...    ..(211 skipped).    ..  *********************
 396    2019-04-04 18:13    40  *********************
 397    2019-04-04 18:14    39  ********************
 ...    ..(247 skipped).    ..  ********************
 167    2019-04-04 22:22    39  ********************
0x01  0x008  4              25  ---  Lifetime Power-On Resets
0x01  0x010  4           11235  ---  Power-on Hours
0x01  0x018  6     17887007872  ---  Logical Sectors Written
0x01  0x020  6       468771742  ---  Number of Write Commands
0x01  0x028  6     86091869971  ---  Logical Sectors Read
0x01  0x030  6       745490584  ---  Number of Read Commands
0x03  0x008  4           11185  ---  Spindle Motor Power-on Hours
0x03  0x010  4           11185  ---  Head Flying Hours
0x03  0x028  4               0  ---  Read Recovery Attempts
0x04  0x008  4               2  ---  Number of Reported Uncorrectable Errors
0x05  0x008  1              40  ---  Current Temperature
0x05  0x010  1              39  ---  Average Short Term Temperature
0x05  0x018  1              37  ---  Average Long Term Temperature
0x05  0x020  1              48  ---  Highest Temperature
0x05  0x030  1              45  ---  Highest Average Short Term Temperature
0x05  0x038  1              35  ---  Lowest Average Short Term Temperature
0x05  0x040  1              42  ---  Highest Average Long Term Temperature
0x05  0x048  1              36  ---  Lowest Average Long Term Temperature
0x06  0x008  4             107  ---  Number of Hardware Resets
0x06  0x010  4              47  ---  Number of ASR Events
                                ||__ D supports DSN
0x8000  4      6414861  Vendor specific
g00mbs
/dev/ada4
~/ $ sudo smartctl -x /dev/ada4
Serial Number:    WD-WX11D3744H24
LU WWN Device Id: 5 0014ee 20eaebf93
Local Time is:    Thu Apr  4 22:22:40 2019 PDT
                    was never started.
                    been run.
data collection:         ( 5744) seconds.
                    command.
                    power-saving mode.
recommended polling time:      ( 711) minutes.
  3 Spin_Up_Time            POS--K   197   196   021    -    9133
  7 Seek_Error_Rate         -OSR-K   100   253   000    -    0
193 Load_Cycle_Count        -O--CK   200   200   000    -    121
194 Temperature_Celsius     -O---K   104   093   000    -    48
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
    ER     = Error register
Error 4 [3] occurred at disk power-on lifetime: 8961 hours (373 days + 9 hours)
  40 -- 51 00 00 00 01 4f 73 30 68 40 00  Error: UNC at LBA = 0x14f733068 = 5627916392
  60 00 d0 00 88 00 01 4f 73 31 68 40 08  1d+15:09:51.072  READ FPDMA QUEUED
  60 01 00 00 80 00 01 4f 73 30 68 40 08  1d+15:09:51.072  READ FPDMA QUEUED
  60 00 40 00 78 00 01 4f 73 30 28 40 08  1d+15:09:51.064  READ FPDMA QUEUED
  60 00 40 00 70 00 01 4f 73 2f e8 40 08  1d+15:09:51.061  READ FPDMA QUEUED
  60 00 08 00 68 00 01 4e 8b ed c0 40 08  1d+15:09:51.060  READ FPDMA QUEUED
Error 3 [2] occurred at disk power-on lifetime: 2093 hours (87 days + 5 hours)
  40 -- 51 00 00 00 00 7d 8f 35 50 40 00  Error: UNC at LBA = 0x7d8f3550 = 2106537296
  60 00 40 00 c8 00 01 60 e1 84 38 40 08 19d+01:52:26.947  READ FPDMA QUEUED
  60 00 40 00 c0 00 01 60 e1 83 f8 40 08 19d+01:52:26.947  READ FPDMA QUEUED
  60 00 08 00 b8 00 00 7c 41 ac e8 40 08 19d+01:52:25.089  READ FPDMA QUEUED
  60 01 00 00 b0 00 00 7d 8f 36 50 40 08 19d+01:52:25.088  READ FPDMA QUEUED
  60 01 00 00 a8 00 00 7d 8f 35 50 40 08 19d+01:52:25.088  READ FPDMA QUEUED
Error 2 [1] occurred at disk power-on lifetime: 1084 hours (45 days + 4 hours)
  40 -- 51 00 00 00 00 4f 72 0d 00 40 00  Error: UNC at LBA = 0x4f720d00 = 1332874496
  60 00 40 00 28 00 01 6b 7f d2 98 40 08 26d+18:02:16.332  READ FPDMA QUEUED
  60 00 40 00 20 00 01 6b 5e 43 a8 40 08 26d+18:02:11.829  READ FPDMA QUEUED
  60 00 40 00 18 00 01 6b 5e 43 68 40 08 26d+18:02:11.829  READ FPDMA QUEUED
  60 00 40 00 10 00 01 6b 5e 43 28 40 08 26d+18:02:11.822  READ FPDMA QUEUED
  60 01 00 00 08 00 00 4f 72 0e 00 40 08 26d+18:02:11.092  READ FPDMA QUEUED
Error 1 [0] occurred at disk power-on lifetime: 83 hours (3 days + 11 hours)
  40 -- 51 00 00 00 00 54 5a 78 30 40 00  Error: UNC at LBA = 0x545a7830 = 1415215152
  60 01 00 00 e0 00 00 54 5a 79 30 40 08  1d+11:52:59.951  READ FPDMA QUEUED
  60 01 00 00 d8 00 00 54 5a 78 30 40 08  1d+11:52:59.951  READ FPDMA QUEUED
  60 01 00 00 d0 00 00 54 5a 77 30 40 08  1d+11:52:59.940  READ FPDMA QUEUED
  60 01 00 00 c8 00 00 54 5a 76 30 40 08  1d+11:52:59.939  READ FPDMA QUEUED
  60 01 00 00 c0 00 00 54 5a 75 30 40 08  1d+11:52:59.928  READ FPDMA QUEUED
Current Temperature:                    48 Celsius
Power Cycle Min/Max Temperature:     42/52 Celsius
Vendor specific:
Temperature History Size (Index):    478 (161)
 162    2019-04-04 14:25    48  *****************************
 ...    ..( 97 skipped).    ..  *****************************
 260    2019-04-04 16:03    48  *****************************
 261    2019-04-04 16:04    47  ****************************
 ...    ..( 57 skipped).    ..  ****************************
 319    2019-04-04 17:02    47  ****************************
 320    2019-04-04 17:03    48  *****************************
 ...    ..(318 skipped).    ..  *****************************
 161    2019-04-04 22:22    48  *****************************
0x01  0x018  6     17838612912  ---  Logical Sectors Written
0x01  0x020  6       511791262  ---  Number of Write Commands
0x01  0x028  6     85867097234  ---  Logical Sectors Read
0x01  0x030  6       786566838  ---  Number of Read Commands
0x03  0x008  4           11184  ---  Spindle Motor Power-on Hours
0x03  0x010  4           11184  ---  Head Flying Hours
0x03  0x018  4             139  ---  Head Load Events
0x03  0x028  4               2  ---  Read Recovery Attempts
0x05  0x008  1              48  ---  Current Temperature
0x05  0x030  1              56  ---  Highest Average Short Term Temperature
0x05  0x038  1              40  ---  Lowest Average Short Term Temperature
0x05  0x040  1              51  ---  Highest Average Long Term Temperature
0x06  0x008  4              91  ---  Number of Hardware Resets
0x06  0x010  4              32  ---  Number of ASR Events
                                ||__ D supports DSN
0x000a  2           13  Device-to-host register FISes sent due to a COMRESET
0x8000  4      6414831  Vendor specific
/dev/ada5
~/ $ sudo smartctl -x /dev/ada5
Serial Number:    WD-WX11D37PE9SV
LU WWN Device Id: 5 0014ee 20eacde20
Local Time is:    Thu Apr  4 22:23:09 2019 PDT
                    was never started.
                    been run.
                    command.
                    power-saving mode.
  3 Spin_Up_Time            POS--K   196   196   021    -    9158
  4 Start_Stop_Count        -O--CK   100   100   000    -    24
  9 Power_On_Hours          -O--CK   085   085   000    -    11212
 12 Power_Cycle_Count       -O--CK   100   100   000    -    24
193 Load_Cycle_Count        -O--CK   200   200   000    -    122
194 Temperature_Celsius     -O---K   103   091   000    -    49
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
Current Temperature:                    49 Celsius
Power Cycle Min/Max Temperature:     43/54 Celsius
Lifetime    Min/Max Temperature:     21/61 Celsius
Vendor specific:
Temperature History Size (Index):    478 (215)
 216    2019-04-04 14:26    49  ******************************
 ...    ..( 20 skipped).    ..  ******************************
 237    2019-04-04 14:47    49  ******************************
 238    2019-04-04 14:48    50  *******************************
 ...    ..( 45 skipped).    ..  *******************************
 284    2019-04-04 15:34    50  *******************************
 285    2019-04-04 15:35    49  ******************************
 ...    ..(407 skipped).    ..  ******************************
 215    2019-04-04 22:23    49  ******************************
0x01  0x008  4              24  ---  Lifetime Power-On Resets
0x01  0x010  4           11212  ---  Power-on Hours
0x01  0x018  6     17896404352  ---  Logical Sectors Written
0x01  0x020  6       507224720  ---  Number of Write Commands
0x01  0x028  6     80337363289  ---  Logical Sectors Read
0x01  0x030  6       733713967  ---  Number of Read Commands
0x03  0x008  4           11160  ---  Spindle Motor Power-on Hours
0x03  0x010  4           11160  ---  Head Flying Hours
0x03  0x018  4             140  ---  Head Load Events
0x05  0x008  1              49  ---  Current Temperature
0x05  0x010  1              48  ---  Average Short Term Temperature
0x05  0x018  1              47  ---  Average Long Term Temperature
0x05  0x020  1              61  ---  Highest Temperature
0x05  0x030  1              58  ---  Highest Average Short Term Temperature
0x05  0x038  1              38  ---  Lowest Average Short Term Temperature
0x05  0x040  1              53  ---  Highest Average Long Term Temperature
0x05  0x048  1              45  ---  Lowest Average Long Term Temperature
0x05  0x050  4              20  ---  Time in Over-Temperature
0x06  0x008  4              87  ---  Number of Hardware Resets
0x06  0x010  4              30  ---  Number of ASR Events
                                ||__ D supports DSN
0x8000  4      6414874  Vendor specific
g00mbs
In post #2 I attached a file with the following:
+                        Scheduled SMART Jobs @1554436943                        +
 smarttest_dayweek = 1,2,3,4,5,6,7
smarttest_daymonth = *
   smarttest_month = 1,2,3,4,5,6,7,8,9,10,11,12
    smarttest_type = S
                id = 1
    smarttest_hour = 03
    smarttest_desc =
 smarttest_dayweek = 7
    smarttest_type = L
                id = 2
    smarttest_hour = 04
    smarttest_desc =
debug finished in 0 seconds for Scheduled SMART Jobs
Posted above
I did a quick Google search and it seems the drives are on the warmer side, but should be ok?
I can take a look as I have 3x Antec TrueQuiet 120 120mm Case Cooling Fans. Maybe they are on the low setting and I can kick them up to the high setting.
Chris Moore
+                FreeNAS-11.2-RELEASE-U1 (31f889bbf) @1554436943                 +
Attaching this file was an interesting change, but I am not accustomed to looking at this as most users don't. I am not complaining.
If I recall correctly, those particular drives WD60EFRX are rated by the manufacturer for up to 50°C for normal operation. High temperature kills drives though, so if you want your data drives to last longer, it is best to keep them cool. I try to keep my drives under 40°C, but my hottest two drives are usually around 42°C. Still, the coolest drives in my system are around 31°C consistently and there are only eight that are 40°C or more, which isn't too bad for a system with 32 drives, I think...
It might be a good idea to bump the speed up. Quiet is nice, but having to spend money to buy new drives is not as nice.
Another thing to look at, all your drives are reporting this:
I see where you show a text that talks about Scheduled SMART Jobs @1554436943 but I don't think it is telling you what you think it is telling you.
Also, from that text file, there is this, just above the section you are referencing:
+                         SMARTD Boot Status @1554436943                         +
SMARTD will not start on boot.
debug finished in 0 seconds for SMARTD Boot Status
+                         SMARTD Run Status @1554436943                          +
smartd_daemon is not running.
debug finished in 0 seconds for SMARTD Run Status
So, to me it looks like you don't have any test scheduled and your SMART daemon is not even running.
So you need to schedule tests of the drives through the GUI. Here is the section of the manual on that:
https://www.ixsystems.com/documentation/freenas/11.2/tasks.html#s-m-a-r-t-tests
I have my system run a short SMART test on a daily basis. I picked 5AM, but a time that is good for you and the other things your system is doing. It only takes around five minutes to complete so it is not a big deal.
I also scheduled a weekly long SMART test to run on Monday morning at 7AM. I work days, so I am on my way to work by that time and it doesn't interfere with my schedule, but you should choose a time that works for you. It usually takes several hours to complete because the long test does a full surface scan of the disk. If I recall correctly, my 6TB drives finish in about 12 hours and access speed is slower during that time but the drives can still be used.
I would suggest that you do long tests on all your drives. The directions on kicking that off manually are in the drive troubleshooting guide I linked to earlier. You can kick them all off at once because they run internal to the drive, they can run concurrently. Several of your drives are exhibiting errors that are worrying, but I feel those errors may be due to excessive heat.
Chris Moore
I won't post the whole thing, because the one from this server is 16,310 lines long, but the part of the debug info that you might want to compair to yours is this:
+                         SMARTD Boot Status @1554470757                         +
SMARTD will start on boot.
+                         SMARTD Run Status @1554470757                          +
smartd_daemon is running as pid 25169.
+                        Scheduled SMART Jobs @1554470757                        +
                id = 1
    smarttest_type = L
    smarttest_desc = Long Self Test
    smarttest_hour = 08
smarttest_dayweek = 6
                id = 2
    smarttest_type = S
    smarttest_desc = Short Daily
    smarttest_hour = 06
smarttest_dayweek = 1,2,3,4,5,7
Note: This is not the home system I mentioned earlier.
I see you don't have a supermicro board, so you would have been unable to take advantage of the PID script to control the fans based on drive temperatures.
You may be interested in testing out the option I worked on to allow you to add a Corsair Commander Pro to your box to control the fans.
https://forums.freenas.org/index.php?threads/opencorsairlink-in-a-jail-to-control-fans.71873/
Chris Moore
You should run the long SMART test on all drives first, but after that is done, run a scrub on the pool.
Pitfrr
I experienced similar issues with this board due to the integrated marvell controller (9172 and 9230).
When disks are connected on it (SATA3_M0/M1 and SATAIII_M0/M3 connectors on the board) I sometimes got one disk dropping from the pool and that was back after a reboot.
Although it was generally accompanied with CAM status: CCB request [...] error console messages but not necessarily.
To eliminate this issue, check if you drives are connected to the marvell controllers or not.
You called your pool "pool"? ZFS really needs more reserved names that can't be used for dataset and pool names.
g00mbs
Long SMART Test results:
/dev/ada0
Local Time is:    Tue Apr  9 18:20:14 2019 PDT
                    was never started.
                    been run.
                    command.
                    power-saving mode.
  9 Power_On_Hours          -O--CK   085   085   000    -    11426
193 Load_Cycle_Count        -O--CK   200   200   000    -    125
194 Temperature_Celsius     -O---K   107   093   000    -    45
200 Multi_Zone_Error_Rate   ---R--   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
    ER     = Error register
# 1  Extended offline    Completed without error       00%     11383         -
Current Temperature:                    45 Celsius
Power Cycle Min/Max Temperature:     42/53 Celsius
Vendor specific:
Temperature History Size (Index):    478 (133)
 134    2019-04-09 10:23    45  **************************
 155    2019-04-09 10:44    45  **************************
 156    2019-04-09 10:45    47  ****************************
 ...    ..(403 skipped).    ..  ****************************
  82    2019-04-09 17:29    47  ****************************
  83    2019-04-09 17:30    46  ***************************
 ...    ..( 35 skipped).    ..  ***************************
 119    2019-04-09 18:06    46  ***************************
 120    2019-04-09 18:07    45  **************************
 ...    ..( 12 skipped).    ..  **************************
 133    2019-04-09 18:20    45  **************************
0x01  0x010  4           11426  ---  Power-on Hours
0x01  0x018  6     18124612036  ---  Logical Sectors Written
0x01  0x020  6       484630361  ---  Number of Write Commands
0x01  0x028  6    102652192759  ---  Logical Sectors Read
0x01  0x030  6       920758729  ---  Number of Read Commands
0x03  0x008  4           11374  ---  Spindle Motor Power-on Hours
0x03  0x010  4           11374  ---  Head Flying Hours
0x03  0x018  4             145  ---  Head Load Events
0x05  0x008  1              45  ---  Current Temperature
0x05  0x010  1              46  ---  Average Short Term Temperature
0x06  0x008  4             313  ---  Number of Hardware Resets
                                ||__ D supports DSN
0x0002  2          153  R_ERR response for data FIS
0x0003  2          153  R_ERR response for device-to-host data FIS
0x0009  2          164  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2          167  Device-to-host register FISes sent due to a COMRESET
0x8000  4      6831872  Vendor specific
g00mbs
/dev/ada1
Local Time is:    Tue Apr  9 18:24:31 2019 PDT
                    was never started.
                    been run.
                    command.
                    power-saving mode.
  9 Power_On_Hours          -O--CK   085   085   000    -    11410
193 Load_Cycle_Count        -O--CK   200   200   000    -    126
194 Temperature_Celsius     -O---K   107   094   000    -    45
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
    ER     = Error register
# 1  Extended offline    Completed without error       00%     11368         -
Vendor specific:
Temperature History Size (Index):    478 (129)
 130    2019-04-09 10:27    45  **************************
 151    2019-04-09 10:48    45  **************************
 152    2019-04-09 10:49    47  ****************************
 ...    ..(395 skipped).    ..  ****************************
  70    2019-04-09 17:25    47  ****************************
  71    2019-04-09 17:26    46  ***************************
 107    2019-04-09 18:02    46  ***************************
 108    2019-04-09 18:03    45  **************************
 129    2019-04-09 18:24    45  **************************
0x01  0x010  4           11410  ---  Power-on Hours
0x01  0x018  6     18074741556  ---  Logical Sectors Written
0x01  0x020  6       486333433  ---  Number of Write Commands
0x01  0x028  6     96660218727  ---  Logical Sectors Read
0x01  0x030  6       802288418  ---  Number of Read Commands
0x03  0x008  4           11358  ---  Spindle Motor Power-on Hours
0x03  0x010  4           11358  ---  Head Flying Hours
0x03  0x018  4             144  ---  Head Load Events
0x03  0x028  4              96  ---  Read Recovery Attempts
                                ||__ D supports DSN
0x8000  4      6832146  Vendor specific
g00mbs
/dev/ada2
Local Time is:    Tue Apr  9 18:24:55 2019 PDT
                    was never started.
                    been run.
                    command.
                    power-saving mode.
  9 Power_On_Hours          -O--CK   085   085   000    -    11397
193 Load_Cycle_Count        -O--CK   200   200   000    -    129
194 Temperature_Celsius     -O---K   110   097   000    -    42
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
# 1  Extended offline    Completed without error       00%     11354         -
Current Temperature:                    42 Celsius
Power Cycle Min/Max Temperature:     38/49 Celsius
Vendor specific:
Temperature History Size (Index):    478 (307)
 308    2019-04-09 10:27    42  ***********************
 329    2019-04-09 10:48    42  ***********************
 330    2019-04-09 10:49    44  *************************
 ...    ..(399 skipped).    ..  *************************
 252    2019-04-09 17:29    44  *************************
 253    2019-04-09 17:30    43  ************************
 ...    ..( 32 skipped).    ..  ************************
 286    2019-04-09 18:03    43  ************************
 287    2019-04-09 18:04    42  ***********************
 ...    ..( 19 skipped).    ..  ***********************
 307    2019-04-09 18:24    42  ***********************
0x01  0x010  4           11397  ---  Power-on Hours
0x01  0x018  6     18131611156  ---  Logical Sectors Written
0x01  0x020  6       487043909  ---  Number of Write Commands
0x01  0x028  6     91577222834  ---  Logical Sectors Read
0x01  0x030  6       796994516  ---  Number of Read Commands
0x03  0x008  4           11345  ---  Spindle Motor Power-on Hours
0x03  0x010  4           11345  ---  Head Flying Hours
0x03  0x018  4             148  ---  Head Load Events
0x05  0x008  1              42  ---  Current Temperature
0x05  0x010  1              43  ---  Average Short Term Temperature
                                ||__ D supports DSN
0x8000  4      6832186  Vendor specific
g00mbs
/dev/ada3
Local Time is:    Tue Apr  9 18:25:17 2019 PDT
                    was never started.
                    been run.
                    command.
                    power-saving mode.
  9 Power_On_Hours          -O--CK   085   085   000    -    11351
194 Temperature_Celsius     -O---K   115   104   000    -    37
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
    ER     = Error register
# 1  Extended offline    Completed without error       00%     11309         -
Power Cycle Min/Max Temperature:     35/43 Celsius
Vendor specific:
Temperature History Size (Index):    478 (431)
 432    2019-04-09 10:28    37  ******************
 453    2019-04-09 10:49    37  ******************
 454    2019-04-09 10:50    39  ********************
 ...    ..(393 skipped).    ..  ********************
 370    2019-04-09 17:24    39  ********************
 371    2019-04-09 17:25    38  *******************
 ...    ..( 30 skipped).    ..  *******************
 402    2019-04-09 17:56    38  *******************
 403    2019-04-09 17:57    37  ******************
 ...    ..( 27 skipped).    ..  ******************
 431    2019-04-09 18:25    37  ******************
0x01  0x010  4           11351  ---  Power-on Hours
0x01  0x018  6     18054918020  ---  Logical Sectors Written
0x01  0x020  6       476281584  ---  Number of Write Commands
0x01  0x028  6     86357142581  ---  Logical Sectors Read
0x01  0x030  6       748669559  ---  Number of Read Commands
0x03  0x008  4           11300  ---  Spindle Motor Power-on Hours
0x03  0x010  4           11300  ---  Head Flying Hours
0x05  0x010  1              38  ---  Average Short Term Temperature
                                ||__ D supports DSN
0x8000  4      6832229  Vendor specific
g00mbs
/dev/ada4
Local Time is:    Tue Apr  9 18:25:40 2019 PDT
                    was never started.
                    been run.
                    command.
                    power-saving mode.
194 Temperature_Celsius     -O---K   106   093   000    -    46
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
    ER     = Error register
Current Temperature:                    46 Celsius
Vendor specific:
Temperature History Size (Index):    478 (425)
 426    2019-04-09 10:28    46  ***************************
 447    2019-04-09 10:49    46  ***************************
 448    2019-04-09 10:50    47  ****************************
 ...    ..( 44 skipped).    ..  ****************************
  15    2019-04-09 11:35    47  ****************************
  16    2019-04-09 11:36    48  *****************************
 ...    ..(335 skipped).    ..  *****************************
 352    2019-04-09 17:12    48  *****************************
 353    2019-04-09 17:13    47  ****************************
 ...    ..( 29 skipped).    ..  ****************************
 383    2019-04-09 17:43    47  ****************************
 384    2019-04-09 17:44    46  ***************************
 ...    ..( 40 skipped).    ..  ***************************
 425    2019-04-09 18:25    46  ***************************
0x01  0x018  6     18006483524  ---  Logical Sectors Written
0x01  0x020  6       519824558  ---  Number of Write Commands
0x01  0x028  6     86064176837  ---  Logical Sectors Read
0x01  0x030  6       788837601  ---  Number of Read Commands
0x03  0x010  4           11299  ---  Head Flying Hours
0x03  0x018  4             141  ---  Head Load Events
0x05  0x008  1              46  ---  Current Temperature
0x05  0x018  1              46  ---  Average Long Term Temperature
                                ||__ D supports DSN
0x8000  4      6832188  Vendor specific
g00mbs
/dev/ada5
Local Time is:    Tue Apr  9 18:28:11 2019 PDT
                    was never started.
                    been run.
                    command.
                    power-saving mode.
  9 Power_On_Hours          -O--CK   085   085   000    -    11328
194 Temperature_Celsius     -O---K   105   091   000    -    47
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
# 1  Extended offline    Completed without error       00%     11286         -
Power Cycle Min/Max Temperature:     43/55 Celsius
Vendor specific:
Temperature History Size (Index):    478 (3)
   4    2019-04-09 10:31    47  ****************************
  25    2019-04-09 10:52    47  ****************************
  26    2019-04-09 10:53    49  ******************************
 ...    ..(391 skipped).    ..  ******************************
 418    2019-04-09 17:25    49  ******************************
 419    2019-04-09 17:26    48  *****************************
 ...    ..( 35 skipped).    ..  *****************************
 455    2019-04-09 18:02    48  *****************************
 456    2019-04-09 18:03    47  ****************************
 ...    ..( 24 skipped).    ..  ****************************
   3    2019-04-09 18:28    47  ****************************
0x01  0x010  4           11328  ---  Power-on Hours
0x01  0x018  6     18066605852  ---  Logical Sectors Written
0x01  0x020  6       515270322  ---  Number of Write Commands
0x01  0x028  6     80658586507  ---  Logical Sectors Read
0x01  0x030  6       737159167  ---  Number of Read Commands
0x03  0x008  4           11275  ---  Spindle Motor Power-on Hours
0x03  0x010  4           11275  ---  Head Flying Hours
                                ||__ D supports DSN
0x8000  4      6832354  Vendor specific
