jafrey
- Dec 24, 2014
I was reading through the zfs man pages and saw that you can use deduplication on send even if it isn't used all the time.
For a test I copied a bunch of images to a scratch ZFS pool and then put copies in 4 subfolders.
Then sent the filesystem to a file with and with out deduplication:
-D Generate a deduplicated stream. Blocks which would have been
sent multiple times in the send stream will only be sent
once. The receiving system must also support this feature to
receive a deduplicated stream. This flag can be used
regardless of the dataset's dedup property, but performance
will be much better if the filesystem uses a dedup-capable
checksum (eg. sha256).For a test I copied a bunch of images to a scratch ZFS pool and then put copies in 4 subfolders.
/mnt/scratch_zfs/test/2015Oct03_111345.cr2 /mnt/scratch_zfs/test/2015Oct03_111353.cr2 /mnt/scratch_zfs/test/2015Oct03_111354.cr2 /mnt/scratch_zfs/test/2015Oct03_111355.cr2 /mnt/scratch_zfs/test/2015Oct03_113914.cr2 /mnt/scratch_zfs/test/folder1/2015Oct03_111345.cr2 ... /mnt/scratch_zfs/test/folder2/2015Oct03_111345.cr2 ... /mnt/scratch_zfs/test/folder3/2015Oct03_111345.cr2 ... /mnt/scratch_zfs/test/folder4/2015Oct03_111345.cr2 ...
# zfs send test@0001 > test.zfs zfs send -D test@0001 > test.zfs -rw-r--r-- 1 root wheel 570M Nov 4 12:08 test.zfs -rw-r--r-- 1 root wheel 115M Nov 4 12:08 test-D.zfs
