Decrypt pool without entering all keys
doughyboy
Is there a way to decrypt just a specific dataset? Each time I go to decrypt my datasets, it prompts me for passwords for all of them.
I usually just spam random characters as I don't want all datasets decrypted, just the primary and children.
Just leave the fields blank.
As long as the specific one you want unlocked is not below a locked parent, you should be fine. Otherwise, you have to unlock all datasets "down the chain" to your desired dataset.
doughyboy
You can't, it requires you to enter all passwords/text regardless of whether it's a parent or child dataset - that's the issue. I only want to unlock the parent, but am forced to enter text into all other encrypted datasets, regardless of whether or not I want them to be decrypted.
Maybe they changed it for SCALE? That's weird if they did...
On TrueNAS Core 13.0-U5, I can choose to unlock specific datasets no problem. The summary will show "red X's" for the datasets that weren't unlocked (the ones I left blank). But after that screen I'm back on the Pools page with my dataset unlocked.
