RoboKaren
- Apr 8, 2014
This is strange. I just received a critical warning that one of my volumes is healthy. I'd understand a warning that it was degraded, or that it was a 9.2.x that needing upgrading, but that it is healthy?
The GUI shows a checksum error with the volume scrub but doesn't give a warning.
It's only when I drop down to the command line do I find out that the zpool command is much more concerned with the checksum error than the GUI is:
TL;DR: It seems to me that the GUI could do a better job of warning the user when the volume is 'healthy' but actually has a disk that may be on the verge of failing.
[nakamura@bethel] ~% zpool status
pool: betheltime
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: http://illumos.org/msg/ZFS-8000-9P
scan: scrub repaired 0 in 31h30m with 0 errors on Thu Nov 27 15:30:08 2014
NAME STATE READ WRITE CKSUM
betheltime ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
gptid/6bf9ffa3-dbcb-11e3-b567-9cb65407d831 ONLINE 0 0 0
gptid/6c724f8a-dbcb-11e3-b567-9cb65407d831 ONLINE 0 0 2
