CPU Usage and VM's
drsassafras
On the dashboard there is an overview of what all the CPU's are doing. I would love to be able to see which ones are assigned to which VM's and their current usage. So a quick visual inspection could help me see what VM's are using more or less CPU usage.
Samuel Tai
bhyve, the Type-2 hypervisor in TrueNAS, doesn't statically assign CPU cores to VMs.
drsassafras
I was just reading about that. Might make it difficult to implement my suggestion in that case. I guess I am just use to it doing that in lower operating systems like Darwin.
You can have a look in htop, it's really obvious what's going on:
  PID USER      PRI  NI  VIRT   RES S CPU% MEM%   TIME+  Command
2973  root       20   0 4156M 1219M S  4.5  3.7 16h08:23 bhyve: 30_Linux
14685 root       20   0 16.0G 9050M S  1.6 27.7 50:14.88 bhyve: 18_Windows
