copy/paste vnc bhyve
spacecabbie
Elloh,
Could someone tell me where are the settings for the vncserver in bhyve? I like to enable optional features like copy / paste and filetransfer.
If it's not possible with the vm tool where is the actual conf located to do it the hard way ?
ty,
I find scp gets the job done for file transfer.
There is no possibility to use any kind of VM tools with the provided bhyve and VNC setup for host/guest transfers to my knowledge.
spacecabbie
Scp sure but i am doing regular install testing setups etc.
Even without using the "approved" way ? are they hard coded in freenas ?
Can you get it working in FreeBSD? if you can, maybe it could be made to work in FreeNAS.
