Controller not found
Hi guys,
after replacing all my hardware I am now running
Supermicro Mainboard H8SML
32GB Kingston ValueRAM DDR3-1600 ECC DIMM
AMD FX-8150
with an additional M1015 card.
I can find the LSI2308 card and attached disks:
[root@freenas] ~# dmesg | grep mps
mps0: <Avago Technologies (LSI) SAS2308> port 0xa000-0xa0ff mem 0xfdbb0000-0xfdbbffff,0xfdbc0000-0xfdbfffff irq 28 at device 0.0 on pci1
mps0: Firmware: 20.00.04.00, Driver: 20.00.00.00-fbsd
mps0: IOCCapabilities: 4185c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,IR>
mps0: SAS Address for SATA device = 49636968dbb1d56d
mps0: SAS Address from SATA device = 49636968dbb1d56d
mps0: SAS Address for SATA device = d43b4661b7fcbb8e
mps0: SAS Address from SATA device = d43b4661b7fcbb8e
mps0: SAS Address for SATA device = 49675b6fd7b7be75
mps0: SAS Address from SATA device = 49675b6fd7b7be75
mps0: SAS Address for SATA device = d4274d69b60ebc76
mps0: SAS Address from SATA device = d4274d69b60ebc76
mps0: SAS Address for SATA device = 49656759ea95dd83
mps0: SAS Address from SATA device = 49656759ea95dd83
mps0: SAS Address for SATA device = 49675b6fd7aebc6f
mps0: SAS Address from SATA device = 49675b6fd7aebc6f
mps0: SAS Address for SATA device = 49675b6fd78fd989
mps0: SAS Address from SATA device = 49675b6fd78fd989
mps0: SAS Address for SATA device = 49675b6fd7aac070
mps0: SAS Address from SATA device = 49675b6fd7aac070
da0 at mps0 bus 0 scbus0 target 2 lun 0
da3 at mps0 bus 0 scbus0 target 5 lun 0
da2 at mps0 bus 0 scbus0 target 4 lun 0
da4 at mps0 bus 0 scbus0 target 6 lun 0
da1 at mps0 bus 0 scbus0 target 3 lun 0
da5 at mps0 bus 0 scbus0 target 7 lun 0
da7 at mps0 bus 0 scbus0 target 9 lun 0
da6 at mps0 bus 0 scbus0 target 8 lun 0
I cannot find the IBM M1015 controller. It is plugged to the pcie2 x8 in x16 slot on the board. Any ideas beside replacing the adapter?
Cheers,
Hubertus
Mirfster
Um has that card been cross-flashed to IT mode? *** Note if you have never cross-flashed a card before, you may want to physically remove the LSI card to ensure you don't run any risk working on the wrong card.
It should be detected regardless of whether its been flashed to IT mode or not.
Many boards (AMD and/or desktop boards) do not support more than 1 RAID controller simultaneously.
Mirfster
mps is a specific set of hardware chipsets for LSI/Avago. I've never heard of mpi. No clue what that is. Either it's something super new or something really, really old.
diehard
MPI is for "Message Passing Interface" , I believe its a method for the RAID controller to pass through information to an OS.
Mirfster
Yep, I was just curious. Since I have never used a M1015 (all H200s here), I did see the mpi trying to load with a LSI MegaRaid 9260-8i before (was trying to see about a BBU Slog setup...).
So I was wondering if the M1015 was in IT mode if it would appear as something like "mpi0" instead of "mps0"; that was all.
