To preface, I'm new to configuring network routing. I originally setup my system on my LAN without any problems, however it has now been moved offsite using a colocation service (colo) as I couldn't keep it in my building (too noisy).
Using FreeNAS's default menu, I updated the network interface to its new IPv4, Netmask, IPv4 default route, and DNS nameservers given to me by the colo. I also updated the line "hostname=" in /etc/rc.conf to its new hostname specified by the colo. Finally the colo has also added the necessary rules to its firewall accepting incoming connections from my IP to my server's IP on ports 22 (SSH), 80 (HTTP), and 443 (HTTPs), and their firewall does not filter outgoing data.
However when I try to ping out from the server (either to my IP or even just Google) I get "No route to host". And if I try pinging the server from my IP I get "Destination host unreachable".
ifconfig shows that it recognizes an active connection on the network interface I've configured. But netstat -r returns nothing. I'm using FreeNAS 9.3.
What am I missing here? Does FreeNAS have a firewall that I need to manually adjust? I couldn't find information on it in the documentation. Otherwise I'm pretty lost. Are there other network configuration files that I have to manually update?
