Compatibility issue with old hardware
Ron Cohen
I tried to install FreeNAS Corral on Intel Quad Core Q6600 that i had.
The problem is after the installation on USB finished the grub of the FreeNAS wont start and stuck on black screen with GRUB written on it.
I tried to install on one of the SATA drives that i will use and the GRUB and FreeNAS started successfully.
So my question is there is known compatibility issue or know BIOS setting that should fixed this problem?
EDIT:
sorry for not mentioning that i tried to install FreeNAS 9.10 and get the same result
Ron Cohen
