clone pool ada1
ekinox
hello,
i have some prob with 1 drives in my freenas and i want to clone all inside to another new drive but the new drive should take the name of the defective drive
i need to tranfer all of this and keep the name, param, jail and data
is it possible ?
i heard about replication task but i don't know if it's really possible
Chris Moore
Chris Moore
If you have configured a storage pool on a single drive, the simplest solution would be to add a second drive as a mirror to the defective drive. This would allow the operating system to handle the operation for you. I think this is available as a menu option from the latest version of FreeNAS. I have not tried it. There is a guide to do it manually here:
ZFS: Adding a drive to create a mirror
https://www.ixsystems.com/community/threads/create-zfs-mirror-by-adding-a-drive.14880/post-81348
