For SDA
[CODE
Device Model: ST4000VN006-3CW104
Serial Number: ###
LU WWN Device Id: 5 000c50 0e6615ec8
Firmware Version: SC60
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Thu Jul 20 08:21:33 2023 BST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity was never started.
Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run.
Total time to complete Offline data collection: ( 0) seconds.
Offline data collection capabilities: (0x73) SMART execute Offline immediate.
Suspend Offline collection upon new command.
No Offline surface scan supported.
Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode.
Short self-test routine recommended polling time: ( 1) minutes.
Extended self-test routine recommended polling time: ( 464) minutes.
Conveyance self-test routine recommended polling time: ( 2) minutes.
SCT capabilities: (0x70bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 081 064 006 Pre-fail Always - 119559600
3 Spin_Up_Time 0x0003 096 095 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 85
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 074 060 045 Pre-fail Always - 24967647
9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 1155
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 85
183 Runtime_Bad_Block 0x0032 069 069 000 Old_age Always - 31
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 4295032834
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 078 064 040 Old_age Always - 22 (Min/Max 21/25)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 111
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 133
194 Temperature_Celsius 0x0022 022 040 000 Old_age Always - 22 (0 18 0 0 0)
195 Hardware_ECC_Recovered 0x001a 081 064 000 Old_age Always - 119559600
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 1152 (174 123 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 8061874732
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 29502102352
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 1155 -
# 2 Conveyance offline Completed without error 00% 1144 -
# 3 Short offline Completed without error 00% 1144 -
# 4 Extended offline Interrupted (host reset) 00% 1144 -
# 5 Extended offline Completed without error 00% 1142 -
# 6 Extended offline Interrupted (host reset) 90% 1118 -
# 7 Extended offline Completed without error 00% 1108 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.[/CODE]
For SDC
Model Family: Seagate Desktop HDD.15
Device Model: ST4000DM000-1F2168
Serial Number: ###
LU WWN Device Id: 5 000c50 069a9e4c7
Firmware Version: CC52
Rotation Rate: 5900 rpm
ATA Version is: ATA8-ACS T
13/1699-
D revision 4
Local Time is: Thu Jul 20 08:23:43 2023 BST
Total time to complete Offline data collection: ( 612) seconds.
Offline data collection apabilities: (0x73) SMART execute Offline immediate.
Extended self-test routine recommended polling time: ( 513) minutes.
SCT capabilities: (0x1085) SCT Status supported.
1 Raw_Read_Error_Rate 0x000f 118 099 006 Pre-fail Always - 176289464
3 Spin_Up_Time 0x0003 092 091 000 Pre-fail Always - 0
0032 094 094 020
Old_age Always - 6182
0033 100 100 010
Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 069 060 030 Pre-fail Always - 90389597394
9 Power_On_Hours 0x0032 048 048 000 Old_age Always - 45805
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 943
183 Runtime_Bad_Block 0x0032 001 001 000 Old_age Always - 107
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 1 1 1
190 Airflow_Temperature_Cel 0x0022 072 052 045 Old_age Always - 28 (Min/Max 17/32)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 120
193 Load_Cycle_Count 0x0032 097 097 000 Old_age Always - 6264
194 Temperature_Celsius 0x0022 028 048 000 Old_age Always - 28 (0 14 0 0 0)
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 39322h+06m+35.694s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 35910839445
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 68362015258
No Errors Logged
# 1 Extended offline Interrupted (host reset) 00% 45794 -
# 2 Extended offline Completed without error 00% 45790 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
lspci
00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 12)
00:01.0 PCI bridge: Intel Corporation Core Processor PCI Express x16 Root Port (rev 12)
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06)
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 06)
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 06)
00:1c.1 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 2 (rev 06)
00:1c.2 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 3 (rev 06)
00:1c.3 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 4 (rev 06)
00:1c.4 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 5 (rev 06)
00:1c.5 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 6 (rev 06)
00:1c.6 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 7 (rev 06)
00:1c.7 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 8 (rev 06)
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a6)
00:1f.0 ISA bridge: Intel Corporation P55 Chipset LPC Interface Controller (rev 06)
00:1f.2 IDE interface: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA IDE Controller (rev 06)
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 06)
00:1f.5 IDE interface: Intel Corporation 5 Series/3400 Series Chipset 2 port SATA IDE Controller (rev 06)
01:00.0 VGA compatible controller: NVIDIA Corporation TU116 [GeForce GTX 1660] (rev a1)
01:00.1 Audio device: NVIDIA Corporation TU116 High Definition Audio Controller (rev a1)
01:00.2 USB controller: NVIDIA Corporation TU116 USB 3.1 Host Controller (rev a1)
01:00.3 Serial bus controller [0c80]: NVIDIA Corporation TU116 USB Type-C UCSI Controller (rev a1)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 03)
03:00.0 SATA controller: JMicron Technology Corp. JMB363 SATA/IDE Controller (rev 03)
03:00.1 IDE interface: JMicron Technology Corp. JMB363 SATA/IDE Controller (rev 03)
04:00.0 IDE interface: Marvell Technology Group Ltd. Device 914d (rev 10)
05:00.0 USB controller: NEC Corporation uPD720200 USB 3.0 Host Controller (rev 03)
08:00.0 SATA controller: Marvell Technology Group Ltd. 88SE9215 PCIe 2.0 x1 4-port SATA 6 Gb/s Controller (rev 11)
0a:04.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller (rev c0)
3f:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers (rev 02)
3f:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 02)
3f:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 02)
3f:02.1 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor QPI Physical 0 (rev 02)
3f:02.2 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved (rev 02)
3f:02.3 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved (rev 02)
Zpool Status
pool: NAS 4tb
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
scan: resilvered 7.25M in 00:00:02 with 0 errors on Mon Jul 17 20:22:35 2023
remove: Removal of vdev 2 copied 11.5M in 0h0m, completed on Sat Jun 3 14:28:32 2023
1.22K memory used for removed device mappings
NAME STATE READ WRITE CKSUM
NAS 4tb DEGRADED 0 0 0
mirror-0 DEGRADED 0 0 0
25d96a6a-8297-4f26-9797-6842598ee77b DEGRADED 0 0 0 too many errors
16ddd527-a1aa-4efb-88cd-cedde5aac775 ONLINE 0 0 0
mirror-1 DEGRADED 0 0 0
f51f935a-11aa-4042-bf0e-42a97aafe895 DEGRADED 0 0 108K too many errors
1f668bcf-a140-437e-a20d-f0791a773c3c DEGRADED 0 0 108K too many errors
mirror-3 DEGRADED 0 0 0
92e67055-b812-4f32-87b1-d1068c4eb163 DEGRADED 0 0 0 too many errors
a596351c-321c-48d7-955f-d0cb1fce7715 ONLINE 0 0 0
errors: 6 data errors, use '-v' for a list
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:01:57 with 0 errors on Mon Jul 17 03:46:59 2023
boot-pool ONLINE 0 0 0
sdb3 ONLINE 0 0 0
errors: No known data errors
Zpool list -vL
NAME SIZE ALLOC FREE CKPOINT EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
NAS 4tb 10.9T 7.38T 3.49T - - 9% 67% 1.00x DEGRADED /mnt
mirror-0 3.62T 3.52T 104G - - 27% 97.2% - DEGRADED
sdg2 3.64T - - - - - - - DEGRADED
sde2 3.64T - - - - - - - ONLINE
mirror-1 3.62T 2.76T 889G - - 1% 76.0% - DEGRADED
sdd2 3.64T - - - - - - - DEGRADED
sda2 3.64T - - - - - - - DEGRADED
indirect-2 - - - - - - - - ONLINE
mirror-3 3.62T 1.10T 2.52T - - 0% 30.5% - DEGRADED
sdc2 3.64T - - - - - - - DEGRADED
sdf2 3.64T - - - - - - - ONLINE
boot-pool 220G 18.3G 202G - - 2% 8% 1.00x ONLINE -
sdb3 222G 18.3G 202G - - 2% 8.32% - ONLINE
